| Re: Sansa Clip+ - Too Good To Be True???
I have the 8GB Sansa Clip (ie without the card slot) and am very impressed. I agree that with the SD card it looks irresistible.
Just a couple of points to consider, though. Like many other players, it does not work gaplessly. Depending on what music you play, that may or may not be a problem to you.
Secondly, you don't get to see many characters on the screen, so it can sometimes be tedious to work out what album you are selecting if they have long titles (eg hard to distinguish between "Vaughan Williams: Symphony Number 7" and another one by the great VW). So you may want to abbreviate your album titles.
Finally, as with all players that have expansion memory, you might want to check whether the expansion works seamlessly with the on-board memory, or do you have to select it separately. Others on the forum may be able to clarify that.
Bye
Xerxes
