Go Back   AVForums.com > Audio Electronics > Portable Music (MP3, iPod etc.)
Today's price checkPowered by
Apple iPod Touch 8GB Black (3rd Generation)
Apple iPod Touch 32GB Black (3rd Generation)
Apple iPod Nano 16GB Black (5th Generation)
Apple iPod Nano 8GB Black (5th Generation)
Apple iPod Touch 8GB Black (3rd Gener...
Apple iPod Touch 32GB Black (3rd Gene...
Apple iPod Nano 16GB Black (5th Gener...
Apple iPod Nano 8GB Black (5th Genera...
Apple iPod Touch 64GB Black (3rd Gene...
Apple iPod Nano 8GB Purple (5th Gener...
Apple iPod Shuffle (3rd Generation) 2...
Apple iPod Nano 8GB Pink (5th Generat...
Apple iPod Nano 8GB Blue (5th Generat...
Apple iPod Nano 8GB Silver (5th Gener...
 More...Prices updated November 25th at 1:30am and include delivery.
Settings for PS3 audio output on Bluray play Ferengo Blu-ray Players 17 10-01-2009 11:41 AM
Best price for Fallout 3 on PS3? Br0ken Gaming Bargains and Discount Codes 15 09-01-2009 6:34 PM
In a quandary...... chrisbin Plasma Televisions 26 07-01-2009 10:21 AM
MP-3 Recorded on CD-R won't play in car. GFK In Car Entertainment (ICE) 6 06-01-2009 10:32 PM
Play.com 3 year warranty on TVs CJROSS LCD Televisions 4 06-01-2009 12:11 PM
Old 06-01-2009, 10:11 AM   #1 (permalink)
GFK
Thanks: Gave 1, Got 3
MP-3 recorded on CD-R won't play in car.
I recorded some MP3 music files onto a CD-R which plays fine on my home Sony CD player, but my car CD player refuses to recognize it. Someone told me that I have to record it in a diffrent format for it to be recognized by the car unit. Please advise. Thanks.
GFK is offline   Reply With Quote
Old 06-01-2009, 12:25 PM   #2 (permalink)
Thanks: Gave 0, Got 54
Re: MP-3 recorded on CD-R won't play in car.
Sounds to me like your car's CD player can't handle MP3-CD's. If it's a bog-standard player or fairly old and doesn't have the MP3 logo on it anywhere that's probably the case. If so, you can burn the MP3 files to an Audio-CD which would play in any CD player. Windows Media Player has this option, as do Nero etc. Note that you'll only get up to 80 minutes of tracks on an Audio CD, regardless of the original MP3 file size.
Another possiblility if it is (MP3 compatible) is that your car player doesn't like the CD-R's you're using, so you could try using another brand.
Hope that helps.
Barock is offline   Reply With Quote
Old 06-01-2009, 1:15 PM   #3 (permalink)
GFK
Hope that helps.
Many thanks for your response. I have already burned the MP3 tracks onto a CD-R, Verbatim brand, which plays well on my home CD Player. The car player is not MP3 compatible. its circa 2000. I think if I re-record the MP3 files into another file format onto a new CD-R, it might work. But what file format?
Old 06-01-2009, 1:49 PM   #4 (permalink)
Thanks: Gave 4, Got 30
You will need to convert the files to AIF format.
You will need to do this using some conversion software before you burn a new CD.
In all honesty one of the easiest ways is to use iTunes to do this, it is just a case of changing the preferences within the software, and click burn cd, which will do the process on the fly.
As the previous contributor says you will only get about 80 mins per cd (10-12 tracks) but iTunes would tell you how much could be done per disk as you go along.
ABC1 is offline   Reply With Quote
Old 06-01-2009, 3:31 PM   #5 (permalink)
LFC_SL's Avatar
Thanks: Gave 972, Got 1,858
You will need to burn it as an audio CD
Trying to burn CD with wav files on it
Opinions expressed here are my own and do not represent those of the AV Forums or its associated websites
Selling my Aluminium Macbook | Trading Rules - Read for Your Protection | DVDs
LFC_SL is offline   Reply With Quote
Old 06-01-2009, 3:36 PM   #6 (permalink)
Do you use Windows Media Player? If so, you don't need any extra software. Just select the Burn menu, then Audio CD from the drop down menu, drag your MP3 files into the Burn List pane, and WMP does the rest, including the coding to standard CD format.
Old 06-01-2009, 9:48 PM   #7 (permalink)
Thanks: Gave 6, Got 1
I had exactly the same problem a while back, burning wav files solved the problem.
Hill1 is offline   Reply With Quote
car, cdr, mp3, play, recorded
