04-12-2008, 1:41 PM
#1 (permalink)
Thanks: Gave 96, Got 3
nano 4g compatible speaker dock ?????
hi,
has anyone got a speaker dock that works and charges the new ipod nano 4th generation please.
i took mine into currys and none of the ones i tried charged my ipod.
please help
looking for a good all round sound and budget is upto say £150
many thanks in advance.
04-12-2008, 4:23 PM
#2 (permalink)
Re: nano 4g compatible speaker dock ?????
Was told by comet that the bose sounddock product code 509710 priced at £145.83 does and the one review of this dock also mentions that it does.
04-12-2008, 4:49 PM
#3 (permalink)
CHEERS,
i was told that the bose sounddock doesnt charge it - but the new bose sounddock 2 does charge it???
but the sounddock 2 is around £215, bit expensive really.
04-12-2008, 5:16 PM
#4 (permalink)
I thought the same, The bloke in the store was sure that it supported the 4th gen nano. I have one on order and will be collecting it this weekend. I will take the ipod to the store and make sure that it charges the ipod before i buy it.They do have 2 sounddocks that look the same the only differance was the product code.He said that they do look and perform the same but one fully supports the new ipods and the other only plays and will not charge new ipods.
06-12-2008, 11:23 AM
#5 (permalink)
has anyone got one please/recomend one
11-12-2008, 7:37 PM
#6 (permalink)
jarol, did it work with the new nano and charge it please.
27-12-2008, 2:06 PM
#7 (permalink)
Hi big_al,
I have been looking at this as well. When my husband went down to check the compatibility with the new
ipod 4g the first thing written on the details is that it will
not charge the new ipods.
The only one we can see at the moment is the Bose which
is the £200 plus model and is too expensive for the charging option in our opinion anyway.
If you do find one please let me know.
Kind regards,
Sue.
28-12-2008, 12:28 PM
#8 (permalink)
Why dont 4th Gen Nano's charge on some docking stations???
Seems crazy that Apple would change the new ipods?
My daughter had a 4th gen Nano for Xmas and was looking at Logic 3 i-station 7 or 8. But we have been told that it will play the Nano but not charge it!
Can anybody explain why, and also how do we know we are buying one that will charge it?!!
28-12-2008, 12:53 PM
#9 (permalink)
Thanks: Gave 0, Got 104
Re: Why dont 4th Gen Nano's charge on some docking stations???
Although I'm sure they would justify it a different way - I think the "why" is probably because we'll all have to buy new accessories now, and hence help line Apple's pockets.
It's extremely annoying. My touch won't charge in the car now.
Dave
SB+ into Chord QBD76, Chord CPM 2600, Chord SPM 600, Chord Chorus 2 inter-connects, Pioneer PDP-428XD, Sky HD, PS3, Sony STR-DA5200ES, KEF Reference 201/2s, MA GSLCR, MA RSFXs, BK XLS300, Rako lighting, Pronto TSU9600 (with lots of prontoscript)
28-12-2008, 7:12 PM
#10 (permalink)
I followed this link IPOD - Logic 3 i-Station 7 White Speakers and according to Curry's both will.
The model 8 will also sync your ipod to itunes where a lot won't.
Hope this helps.
28-12-2008, 7:40 PM
#11 (permalink)
i got the gear 4 houseparty 4 from comet, £50.
it charges and works fine, good sound too
29-12-2008, 10:25 AM
#12 (permalink)
Oh, great......many thanks for that will take a look today.
29-12-2008, 1:09 PM
#13 (permalink)
Thanks: Gave 2, Got 1
Interesting thread, I was about to buy an Intempo iDS-05 but they seem to be only sold by Amazon with a 1-2 mth potential wait time. (plus I don't know if they charge !).
May look at the 4 houseparty 4 in that case.
31-12-2008, 3:01 PM
#14 (permalink)
I went to Comets today and bought the Bose sounddock which was £145. I did see one at £125 and another at over £200 but couldn't see any difference in looks between the two cheaper ones.
This one charges my new ipod nano 4g...the only down side
is that you can't navigate on the remote control. All you can do is play and stop fast forward next and last track.
Beautiful tone to it and I'm well pleased...not sure about my neighbours though.
04-01-2009, 9:04 PM
#15 (permalink)
Hi all wife just got new 8gig nano 4g and i hooked it up to my xbox 360 and played it through my sony 5.1 surround sound system (sounded great). The xbox 360 WILL PLAY AND CHARGE the ipod nano. Just turn the xbox off when your done to eject ipod etc
