3.5 million visitors each month
Go Back   AVForums.com > Audio Electronics > Portable Music (MP3, iPod etc.)
Today's price checkPowered by
Apple iPod Touch 8GB Black (3rd Generation)
Apple iPod Touch 32GB Black (3rd Generation)
Apple iPod Nano 16GB Black (5th Generation)
Apple iPod Classic 120GB Black
Apple iPod Touch 8GB Black (3rd Gener...
Apple iPod Touch 32GB Black (3rd Gene...
Apple iPod Nano 16GB Black (5th Gener...
Apple iPod Nano 8GB Black (5th Genera...
Apple iPod Nano 8GB Purple (5th Gener...
Apple iPod Touch 64GB Black (3rd Gene...
Samsung YP-P3JCB 8GB Black
Apple iPod Nano 8GB Blue (5th Generat...
Apple iPod Classic 160GB Black
 More...Prices updated November 8th at 8:30am and include delivery.
How do I play MP3's on the Wii? cu3ed Wii 11 12-04-2007 11:04 PM
Does the TEAC Ref 250 play MP3's? normski205 Hi Fi Systems and Separates 0 01-07-2006 12:35 PM
MP3's WON'T PLAY! ray-s DVD and Blu-ray Recorders, Recording and Media 1 06-07-2005 5:49 AM
NW-HD3 does it really play MP3's toratosaru Portable Music (MP3, iPod etc.) 15 16-03-2005 8:00 PM
Will the Sony PSP be able to play MP3's? Funky PSP 6 02-01-2005 9:06 AM
Old 04-08-2008, 1:16 PM   #1 (permalink)
Some mp3's wont play on my PS3, why?
I occasionally plug my sony mp3 player into my PS3 so i can listen to the music through my tv. I download my music from MP3fiesta.com and for some reason any mp3's i've down there don't work. The PS3 will play any mp3's that i've copied onto the mp3 player from CD but not the ones from MP3fiesta. The MP3's from MP3fiesta are unprotected and are at 320 kbps and my sony mp3 player has no problems playing them.
Anyone got any ideas what is going on?
Tommy C is offline   Reply With Quote
Old 10-08-2008, 6:49 PM   #2 (permalink)
Re: Some mp3's wont play on my PS3, why?
Hello Tommy
I'm in the same boat. A percentage of my collection doesn't play on my PS3 either. I use TVersity but I know that's not the problem because I've tried running some of the problematic files from my Vista laptop & direct from an SD card in the PS3 itself. The PS3 simply says that "the data type is not supported."
I've tried a bit of research & there's some talk on the web that the latest firmware may be causing a problem. Also I've tried using an MP3 analyzing program to see if there is a common feature of the files which won't play, (bitrate, encoding type, etc). There isn't.
One thing that did strike me though Tommy, was when you mentioned that your files had come from MP3Fiesta & it occurred to me that 99% of the files I cannot get to play are from MP3Fiesta too. There are a few I've got from them which are OK but the rest cause this problem. So, I think we've hit on a commonality here. The problem is that these are supposed to be plain old MP3s which should play on anything, but they don't. Further research on the web reveals people having problems getting MP3Fiesta MP3s to play on their ipods.
So far I haven't found an answer, please let me know if you find one. It should be possible to re-encode the files and get them to play but that would mean a loss of quality.
hamphlet is offline   Reply With Quote
Old 11-08-2008, 2:34 PM   #3 (permalink)
LFC_SL's Avatar
Thanks: Gave 963, Got 1,813
I would speculate Sony are protecting their business interests in not being overly quick in supporting music obtained from discount Russian websites. But that is only idle speculation on my part
LFC_SL
Opinions expressed here are my own and do not represent those of the AV Forums or its associated websites
Greatest debut album | Trading Rules - Read for Your Protection | DVDs
LFC_SL is offline   Reply With Quote
Old 17-08-2008, 7:20 PM   #4 (permalink)
I would agree with you except for the fact that I have a lot of MP3s from MP3Search, Gomusic and MP3City, none of which exhibit the same problem. And anyway, how would Sony's software differentiate between MP3s provided by one web site & another?
Old 17-08-2008, 7:40 PM   #5 (permalink)
LFC_SL's Avatar
Twas mere speculation But it is a curious coincidence nevertheless
Old 23-08-2008, 12:19 PM   #6 (permalink)
I found this discussion by googling a similar question. My Ipod wont play any files from mp3fiesta, in addition it crashes all the time, after having transferred such files onto it, so that nothing else can be played on it either. I now have to go thru my collection and convert what i have downloaded from them to another format (by using a third party prog such as Media Jukebox, and converting from for ex 256 kbps to 192). i have tried this with a number of tracks and they are then playable. What worries me is the odd track i might have left on the ipod by mistake which may cause it to freeze in the future.
Like another poster, i have tried to diagnose fiesta files, but they dont seem to be marked with anything that differentiates them from other files. A mystery.
esspee is offline   Reply With Quote
Old 29-09-2008, 2:20 PM   #7 (permalink)
I believe the issue is related to some encoding options within mp3 which PS3 cannot decode.
I have a lot of mp3 files which I encoded from my CDs using Lame with the -r3mix switch... Nearly 75-80% of those cannot be played on PS3!
Looking forward for a firmware update that would solve the issue.. Would hate to have to re-encode EVERYTHING!
becharab is offline   Reply With Quote
mp3, play, ps3
