25-10-2007, 3:38 PM
#1 (permalink)
Thanks: Gave 4, Got 6
EU volume capping, should I buy ipod abroad?
Hello. I was about to buy a 160 gb ipod. Googling for a good price, I kept coming across forums dealing with the issue of low volume on the classics. I know that in the past, go pod has been the answer, but is there currently a safe solution that works? If not, and I get someone to collect an ipod from The States, is my guarantee international? If I bought from the Apple shop in Boston, would I be able to return it to Regent Street if necessary?
25-10-2007, 3:56 PM
#2 (permalink)
Thanks: Gave 568, Got 588
Re: EU volume capping, should I buy ipod abroad?
Is this not the same issue that my old 3G suffered from ? Does itunes now allow you to override this ?
Is going to the States for it not overkill ? I have a few ipods and each one has had a volume limit preset on it. A few clicks and it was fixed.
If this is different then this is something new to me.
:: Flickr::
Nothing like a 1000G 's - Need some help, need a 360 Bubby - See Here
25-10-2007, 3:57 PM
#3 (permalink)
Thanks: Gave 41, Got 150
I dunno about the iPod, but I know for most other players you can just download and install the American firmware for the player.
Xbox 360 Gamertag - WelshBluebird1
Xbox 360 Games - PGR3, CoD3, champions League 2007, GRAW and Gears Of War.
My Blog | My Myspace
My Bebo | My Last.FM | My Photos
25-10-2007, 4:22 PM
#4 (permalink)
>Is going to the States for it not overkill ? I have a few ipods and each one has had a volume limit preset on it. A few clicks and it was fixed.<
I'm not going there myself, but my daughter is visiting Boston next month. I'd much rather buy it here though.
What were the clicks? I know there is always a way that the user may set their own maximum volume, but this is different, so far as I can tell. The ex-EU models have a much higher max than EU models.
Here are some forums that I noticed: <forum.macrumors.com>, <soundonsound.com>,< ilounge.com>
26-10-2007, 12:30 AM
#5 (permalink)
Thanks: Gave 747, Got 501
Seem to recall using a program called eupod a few gens back....
"PS3 Friend Name - KieronUK"
All views expressed are my own. Sorry if you don't agree with my viewpoint!
26-10-2007, 1:44 PM
#6 (permalink)
Thanks for that. Unfortunately it seems to be a PC only fix, and I'm a Mac user. I guess I'll go for the foreign option, not wishing to take any chances. I can't say that this shortcoming with EU ipods is anything that I'm aware of through personal experience, it's just stuff that I've read. But $349 translates to about £170, which makes it cheap enough to wait for the US version.
