AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Portable Music (MP3, iPod etc.)
LinkBack Thread Tools Display Modes
Old 05-08-2006, 2:41 PM   #1 (permalink)
robroy_2000
Posts: n/a
samsung YP Z5
try to get my samsung YP Z5 to work and i running window me and i need media player 10 can anyone help
thank you
Old 05-08-2006, 5:20 PM   #2 (permalink)
Thanks: Gave 1, Got 3
Unhappy
If you need an ME driver you can get one here:
http://org.downloadcenter.samsung.co...0_MTP9x-2k.exe
If you need to run WMP 10 I think you may be out of luck with ME
Biskitboy is offline
Old 05-08-2006, 6:31 PM   #3 (permalink)
robroy_2000
Posts: n/a
thank you
Old 07-08-2006, 8:54 PM   #4 (permalink)
power drain
i've just purchased a YP Z5 and can't seem to turn the thing off. As a result the power just constantly drains away. I'm obviously missing something, so if anyone could share their knowledge on how to successfully turn the machine off i would be incredibly grateful. Cheers h
hoybrown is offline
Old 07-08-2006, 9:19 PM   #5 (permalink)
Thanks: Gave 0, Got 27
Hold down the play/pause/power button until the display goes dark. If that doesn't work there's something wrong with it. The Z5 does have some power quirks resulting in the battery running down on me far more often despite the nominally great battery life, but remembering to powering it off will avoid problems.
extremelydodgy is offline
Old 07-08-2006, 9:50 PM   #6 (permalink)
thanks for the advice, i'll give it a try.
hoybrown is offline
samsung
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
