Thanks again with your knowledge Mark - much appreciated.
Is there any reason why the sky recordings look slightly soft compared to DVD recordings - I'm guessing as they are recorded at a lower resolution and sized to fit the screen? Not that that helps at all, I'm just happy that I can record from sky now after all my teething problems.
One last question (which may or may not be able to be discussed on here), is there any simple way of making the sky files smaller? A regular 2.5 hour film is close to 2 gb - at this rate, my 160gb will be filled in no time! If it makes any difference, I'm on a Mac so most conversion programs don't apply here. At present, I'm using Handbrake but this seems to throw the sound out of sync?
I guess I'm not asking anything illegal as it is legal to record - all I'm trying to do is make the files smaller?
Any advice is gladly welcomed and have a happy and peaceful Christmas (impossible in my house with 2 small children).
