Archos AV500 connect to PC problem
Old 15-08-2007, 2:35 PM   #1
pwb1969
Posts: n/a
I've been using the Archos AV500 for quite a while now, and whilst it has its limitations, it serves my purpose and I love it.
However, I've now just come across a problem in that my PC no longer recognises my Archos, only listing it in Explorer as a Removeable Drive. WMP also doesn't recognise it any more as when I go to sync it up, it doesn't find any suitable device. When I've clicked on the Removeable Drive, it comes up with the message
" The disk in drive F is not formatted. Do you want to format it now?"
I'm guessing not, since it will wipe everything off!
I've tried system restore, I've checked the settings on the Archos itself, and the USB port is set to 'Hard Drive' which is correct. The machine works fine as stand alone, but just not with the PC any more.
Am I doing anything wrong? I can no longer access the Archos via the PC and I can't add any more music to it - and I go on holiday in 7 days time!
Any help / guidance would be greatly appreciated.
Old 17-08-2007, 9:57 AM   #2
5,036, Level: 16
Points: 5,036, Level: 16 Points: 5,036, Level: 16 Points: 5,036, Level: 16
Thanks: Gave 0, Got 12
Re: Archos AV500 connect to PC problem
If you want to sync stuff to it, you need to set it as a windows device rather than as a hard drive. You do this in the system settings on the Archos.
Old 17-08-2007, 5:37 PM   #3
7,462, Level: 20
Points: 7,462, Level: 20 Points: 7,462, Level: 20 Points: 7,462, Level: 20
Thanks: Gave 4, Got 5
U could also try to connect using a different USB port on your PC.
Old 17-08-2007, 9:32 PM   #4
5,196, Level: 17
Points: 5,196, Level: 17 Points: 5,196, Level: 17 Points: 5,196, Level: 17
Thanks: Gave 0, Got 45
Did you try a system restore on your PC to a date when the Archos was recognised by your PC.
Old 21-08-2007, 2:37 PM   #5
pwb1969
Posts: n/a
Apologies for not being able to reply sooner, but I've ben working away. I also asked the question on another post (Archos forum) and got a fantastic response which totally resolved my problem. Therefore in case anyone ever comes across this in the future, please find below what to do;
http://www.cgsecurity.org/wiki/TestDisk
http://www.cgsecurity.org/wiki/TestDisk_Download
Guys, after intensively searching the net for a solution to a problem a number of us (including me) experienced where the AV500 stops being recognised properly by Windows, I'm elated to report that I have found a 100% effective and very easy solution, which has just worked for me, and I'm now able to access the device properly again, without having lost any data!
Go here: http://www.cgsecurity.org/wiki/TestDisk
and download a free utility called TestDisk (I downloaded the latest NON-beta version). It's a zipped file, just extract all files to a folder of your choice leaving the option "Use folder names" checked. Then, go to the folder where you unzipped the files, go to the Win folder, and run the testdisk-win.exe file. It runs in a DOS window, even though it says it's a Windows app, but it doesn't really matter at all.
Another note, and just to recap, the problem I was having is that Windows (XP SP2) stopped recognising my device properly. It would show up as a removable drive with a letter assgined to it under Explorer or My Computer, but when double clicking on it, I'd get a message "The drive (letter) is not formatted. Do you want to format it now?". CHKDSK utility under DOS reported the drive was in RAW format, and unsupported. So, I can vouch that if you're having the EXACT same problem, the following procedure will work, otherwise, if your problem is different, use at your own risk, or contact the maker of the software direct for advice, he was very quick in replying to me, and extremely helpful!
So, start the app (you must run it with administrator privileges), wait for it to recognise all the drives, it will take 5-15 seconds. Choose the AV500 drive. Confirm Intel/PC partition. Analyse it. Proceed. Enter to continue. Write on the next menu. Confirm. Quit the app. Disconnect USB cable from the device following the safe hardware removal procedure. Reboot your pc. Re-connect the device and it should be properly recognised, and the whole thing doesn't take longer than a couple of seconds!
And it really works....
Old 27-01-2009, 1:00 PM   #6
AnneG
Posts: n/a
Thank you so much - this worked a treat!
Powered by
 Latest popular product prices
Samsung YP-F3 4GB
2 prices from
 £17.99 Click to show/hide the offers
Samsung YP-F3 4GB
2 prices from
Samsung YP-F3 2GB
2 prices from
 £18.49 Click to show/hide the offers
Samsung YP-F3 2GB
2 prices from
Archos 18c Vision 4GB Black
5 prices from
 £19.49 Click to show/hide the offers
5 prices from
Goodmans GMP38G9 8GB
1 price
 £35.81 Click to show/hide the offers
1 price
 Updated February 14th at 1:30am. Prices include delivery.
[IMG] code is Off
