| Re: Help with my ARCHOS AV500
The Pod is "one directional" if you can record from the TV then you will need to plug the same lead into your DVD player scart out socket. The set up of the pod is a pass thru device with an input and output. Obviously it can only record from the source connected to the input. If it can record from your TV scart then the Pod and Archos are working fine.
Note your DVD player might have two scarts but that might be for play through as well, the second scart socket might not output a signal. Also it might be worth reading your DVD manual to see what the various scarts output.
I hope this make sense.
