| How to record tv/v+ for use on portable system
Not sure exactly which forum this fits into but hopefully you guys can help. Is there a relatively straight forward and not overly expensive way to record programmes from tv and/or a v+ box? This would mainly be used to record kids tv and play back on in-car dvd player which I believe reads dvd, div x, mpeg. Ideally, I'd be able to copy/save them onto a portable hard drive which can connect to the dvd player via usb. The only thing I've seen that I think will fit the bill is an Archos with the dvr dock but that is quite expensive. Is there anything cheaper or can I use my laptop in any way?
Any advice much appeciated.
