| Re: Archos 5 - a disaster?
Hawk - what firmware are you on? The most stable is apparently the .53, the subsequent .54 was causing a lot of crashing and problems similar to yours - although it sounds like you have had trouble updateing the firmware anyway....the most recent firmware doesn't make a lot of difference by all account so no need to update if nothing is wrong.....problem with the .54 and the latest firmware is that it is not donwgradeable once you have installed it..
Its a shame you are having those problems because, when it works, the A5 is great - I've not had any of those problems with mine and have been enjoying it immensely.
As for 30 minutes on a full charge that seems like a pretty serious problem, so clearly a faulty unit - you only get a few hours anyway, without the battery dock, but 30 minutes is taking the mickey - hope you get it sorted.....
As for the android - pop over the the ARCHOSFANS FORUM (google it!) and there is plenty of info on there about all the archos models
