| Re: Archos 504 - PC connection problem
Welcome to the forums.
Please do not make the same post in multiple threads, just post once.
I have moved your post into in a new thread for you.
A couple of suggestions to help with your problem:
1. Try using a different USB port, sometimes you will have more success with the port you originally used when you first connected the Archos.
2. Try disconnecting any other USB devices then see it is recognises the 504.
3. It may be that the USB cable is faulty, if possible try a different cable or if you have a dock then connect to the PC via the dock using a different cable.
