Panasonics (European models) 24p, telecine inversion and bandwith: Current status
Old 23-11-2008, 5:49 PM   #1
2,383, Level: 11
Points: 2,383, Level: 11 Points: 2,383, Level: 11 Points: 2,383, Level: 11
Thanks: Gave 24, Got 18
A lot about this has been said already, so I was a bit surprised that there isn't a 100% definitive answer (unless I really suck at googling). Let's clear it out so I can finally decide to buy now or wait for the next generation (G12) panels. Do read carefully, I've noticed that in videoland every detail matters:-). My apologies if everyone has figured this out already:-)
1. 24p playback and Real Cinema (24p blue-ray source!):
  • In the case of the BR player outputing 24p the Panasonic does a 4:4 pull down, effectively using a 96hz refresh rate = No judder = IFC (intelligent frame creation = disabled). This is called native 24p playback.
  • Same scenario as just above but with IFC enabled. What does this exactely do? Add 4 frames so the refresh rate is 100hz? This is called Real Cinema and does some nasty things? I'm asking this because no one mentions the refresh rate when using Real Cinema.
2. Things that should be treated as 24p but are not detected as such, causing improper deinterlacing of film content, not video content!
The main thing leading to my confusion is people talking that the deinterlacer is bad. Whilst it correctely deinterlaces video mode material. So IF I get it correctely it should somehow extract 24p from 1080i broadcasts only and only if the broadcast is film. The technique used to do this is called reverse 3:2 pulldown?
  • What does this mean for 1080/50i as I think 3:2 reverse pull down is only for 1080/60i.
  • As I understand, it uses video deinterlaceing mode instead of film deinterlacing mode beacause it cannot recognize the difference between 24p film and normal video. What the heck is normal video then? And what is broadcasted in normal video?
  • Couldn't we just force a setting that sets the panasonic to film deinterlace?
3. a third and (luckily) final issuse is concerned with the bandwith
This site states that motion resolution goes up to 1080p as long as IFC is turned off.
Panasonic TH42PZ85B Plasma HDTV Calibration & Benchmark
But if you check out this PDF, no panasonic gets the full 1080 lines:
http://hdguru.com/wp-content/uploads...-125-hdtvs.pdf
I know the panasonic in the first link (TH-42PZ85B) is not listed in the PDF of the second link. But this one is:
Panasonic TH42PZ80 / TH42PZ80B Review: 42" Viera Plasma HDTV
Why does hdguru.com get other results then hdtvtest.co.uk? Is there such a big difference between US models and UK models?
And just for the record could somone please explain the issue with motion resolution vs static resolution. I get it is an issue, but haven't a clue why.
I hope the answers for these questions are useful for many of us noobs:-)
Cheers,
Jeroen
Old 23-11-2008, 10:13 PM   #2
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Points: 20,236, Level: 34 Points: 20,236, Level: 34 Points: 20,236, Level: 34
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 369, Got 613
Re: Panasonics (European models) 24p, telecine inversion and bandwith: Current status
1. ok so you don't want guesses but I'm going to guess. IFC on will give you 2 (identical) frames of source then 2 (identical) frames of invented interpolation, then 2 frames of source. So a 96Hz picture with a simulated 48Hz source.
2. When 1080i/50 film material is processed by something that can do IVTC, it just converts it to 1080p/25.
Normal video is anything that was "filmed" in 50Hz (or 60Hz) interlaced using a video camera, like sport and most TV shows. A good example is The Wire. You'll often find rips that have converted this to 24fps thinking it was shot on film but they judder like a good un. A 60Hz rip on the other hand is smooth because that's how it was recorded.
No you can't force a setting because the Pannies can't do it. They still give a very good result for the price.
3. It's down to personal interpretation of what people are seeing. Motion resolution is lower than static because the pixels have to change colour as things move and how quickly and accurately they can change colour dictates how much detail is still visible during motion.
Old 24-11-2008, 10:09 AM   #3
2,383, Level: 11
Hi Choddo,
Thanks for taking the time to make me a little smarter
Regarding 2. The Pannies should deinterlace 1080i/50 film content, convert it to 24p and then do a 4:4 pull down but they can't? Or they can but are unable to recognize (watch out I've picked up a new word here) the film cadence?
Let me clarify this a little further:
Video: they deinterlace to 25p and then do a 4:4 pull down = 100hz
refresh rate.
Film : they do the same but actually they should deinterlace to 24p and then do a 4:4 pull down (getting us to 96hz). Question remains whether they just lack the algorithm for it (as you say they can't), or whether they just don't spot the broadcast as being fillm. Shame that a lot of cheaper tv's can do this. I do wonder if I would be able to see the difference between a TV that does this properly and one that does not. After all, at this point its only numbers to me.
Regarding 3 I'm still a bit information hungry. I've noticed that LCD's in some worst case scenario's only get to a shameful 500 lines (that's less than SD television!). Have you per chance come across some good articles explaining the tech. details that go behind this bandwith issue?
Of course, feel free to give your understanding about it!
cheers,
Jeroen
Old 24-11-2008, 8:19 PM   #4
10,814, Level: 24
Points: 10,814, Level: 24 Points: 10,814, Level: 24 Points: 10,814, Level: 24
Activity: 0.7%
Thanks: Gave 45, Got 662
cheers,
Jeroen
TVs lose resolution when movement occurs. LCDs are worse than plasma for this, though the very latest are catching up. Even the Panasonic only claim 900 lines (with IFC enabled), but 500 is good for an LCD, 800-900 for plasma.
Old 25-11-2008, 12:25 AM   #5
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
refresh rate.
No. Video should be deinterlaced to 50p as it was recorded at 50fields per second. The screen (or processor) should just fill in the blank lines in each field. The better they do that, the better the end result.
No. In this case you want 25p out (with a 2:2 or 4:4 cadence if you like) because you can't convert 25 to 24 cleanly.
I don't think they try.
Are you sure cheaper TVs can? And if they can, do they get it right?
It's not bandwidth, it's the response speed of the pixel to accurately change colour fast enough.
Old 25-11-2008, 10:35 AM   #6
2,383, Level: 11
I believe the samsungs in the same size and price range do this correctly.
And I thought we got rid of the old 4 % 'PAL' speed up. But since it should be converted to 25p (I'm rambling about deinterlacing film from 50i to 25p here) it is still there.
However, both items you describe always amount to 100hz and never get us to 96hz? My calculated guess is that only 24p signals are displayed at 96hz? So the feature will only be used when a blue-ray player outputs 24p (or any other source capable of doing this)?
I must admit I do not understand how deinterlaced film from 50i to 50p is any different from deinterlaced film from 50i to 25p as the TV is 100hz. I thought the good Pioneers engineers had invented some magic to get 50i film to 24p and then display it at 72 of 96 or 120hz.
The way I thought it to be working was quite wrong and how you describe it should be done does not make sense to me.
Old 25-11-2008, 2:03 PM   #7
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
We have got rid of 4% speedup with BluRay @ 1080p/24 but with anything broadcast at 50Hz, you're stuck with it.
Yes but you shouldn't really care.
HD DVD, HTPC, AppleTV, PopcornHour, TVix.
I don't think the TV being 100Hz is relevant to be honest. A 50Hz TV would be the same.
As for 50i->50p or 50i->25p being the same ...
if the process is that both fields are weaved together to produce 25p then doubled to display 50p then they're both effectively the same.
If on the other hand, the process is that each field is bobbed (or a derivative) to produce 50 individual frames (which is what you DO want for video sources) then they're not the same. This is what the Pannies seem to do.
Nope. This is difficult because: Assuming you want to keep things smooth and not drop frames... after 1 second, you'd have an extra frame received by the TV from the source which you need to store until you want to display it. After 2 seconds, you're 2 frames behind.
At the end of a 2 hour movie, you're obviously 4% or 4.8 minutes behind = 54Gigabytes of uncompressed video data @1080p/24fps/24bit colour. Where's that going to go?
I don't see why not. 4% speedup is by far the least bad way of handling film at 50Hz.
Jeroen1000 (25-11-2008)
Old 25-11-2008, 2:39 PM   #8
2,383, Level: 11
Now this is the stuff you never get out of a salesman.
I think I gets it Video has 50 unique frames but is broadcasted as interlaced. So we just want to make it progressive (= 50p @50hz). Showing it as 100hz means we just show each frame twice, which makes a smoother picture. But as you say is quite irrelevant to the process itself.
Film is also broadcasted as 50i but the TV should say hmmm, this is film so I have to do reverse telecine or else I'll be weaving the wrong fields together. In simple words the TV should not treat film as having 50 unique frames. It probably makes up a frame here and there.
What a revelation to me:-)
Old 25-11-2008, 2:54 PM   #9
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
Yep, almost there.
Not IVTCing 50Hz film doesn't mean you weave the wrong fields though, it means you don't weave them at all and you instead make up (as you do with video) the blank lines in each field. It's possible to get a pretty good picture doing this especially with diagonal detection /smoothing. It's not just a simple case of doubling each line which produces nasty stepping on diagonals, especially on SD. Go look in a Sony Centre at one of their cheaper sets for an example
Displaying 50fps material at 100Hz doens't necessarily mean it's smoother (although IFC might claim to do so if turned on) - it just means the picture is more solid and flickers less (although there's an argument that since plasma flashes its pixels on & off really fast in order to produce different colours anyway, it's not quite as clear cut as the CRT days)
Oh and video is normally actually recorded/digitised (as well as broadcast) as interlaced too, to save space.
Old 25-11-2008, 3:51 PM   #10
2,383, Level: 11
Yep, almost there.
I do not believe Pannies make up half the field of a frame when it comes to deinterlacing 50i video. They take the first field and then the second, and deinterlace them (weaving them together). I'll have to rest my brain for a while know:d
Or were you pointing out somthing else?
This comes not from my own knowlegde but from many many internetsources I've browsed this week.
Old 25-11-2008, 4:31 PM   #11
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
They absolutely don't do that. You're getting it the wrong way round. That's what Pioneer's deinterlacer does with film.
Anything that did that with video (e.g. SkyHD's deinterlacer when trying to handle bloomberg tickers) would mess up big style and you'd have horrible combing on the edges of anything moving that was remotely contrasting colours. Think about it. You've got different fields captured 1/50th of a seconds apart. If something has moved in that time, and you try to just weave together the two fields... they don't line up! Whereas with film you've got a single frame which has been split into two fields, so they do match up when you weave them back together.
(edit: Worth mentioning that most video processors can detect motion and decide to weave video in part of a frame where there isn't any but I'd be amazed if the Panny doesn't do this and not sure on the Pioneer)
The question is; do Pannies treat film as video as well, or do they do what Pioneer do? Every technical test I've seen suggests they treat it as video because test disks with single pixel height lines (i.e. lines which exist in one field but not in the next) shimmer on & off when deinterlaced, but I'm more than interested to know if they've changed that with VReal3. They're desperately short on technical detail when you dig.
Old 25-11-2008, 5:10 PM   #12
10,814, Level: 24
Activity: 0.7%
Yes, you are correct. All the technical reviews say the panny (along with lots of others) does not deinterlace broadcast film material correctly. But it's video processing is fine.
To show the film based material correctly you have to combine (deinterlace) two 50hz frames together to make one 1080p image. Also note that HDTV Test said that it wasnt actually a big deal, you do get more "noise" - jaggies and moire effects.
Old 26-11-2008, 10:59 AM   #13
2,383, Level: 11
Choddo, your patience with noobs is really exemplatory!
To be honest I missed the key fact that the fields in progressive material represent the same instance in time. And with interlaced this is not the case. Now all your replies fall into place for me.
Having read up on the matter, it would seem that deinterlacing 50i film is a lot easier than 60i film ('PAL' vs 'NTSC').
Can you confirm that this is called 2:2 cadence with 50i and 3:2 cadence with 60i? And is this terminology equal to 2:2 pulldown and 3:2 pulldown?
Old 26-11-2008, 11:50 AM   #14
Kalos Geros's Avatar
5,698, Level: 17
Points: 5,698, Level: 17 Points: 5,698, Level: 17 Points: 5,698, Level: 17
Activity: 8.1%
Activity: 8.1% Activity: 8.1% Activity: 8.1%
Thanks: Gave 4, Got 73
The term "cadence" describes the structure of video, "pullup" and "pulldown" are actual processes that create / recreate frames to/from cadences...
Panasonic Tvs are notorius for discarding the whole field on 2:2 and 3:2 signal...at least they could force BOB if processor is unsure instead of discarding half a resolution...curiously, I believe they actually use weave when they detect the scene is not moving, but when it is, the whole field gets removed...but don't be sad previous Philips series 5 is even worse in that on the same shot it weaves the picture until something passes in front of the camera,then it goes haywire and drops the whole field, after the object had passed through the shot, it reverses to weave but remains unstable, constantly droping in/and out of the weave...
Pioneer 490 DVD players, just like Panny plasmas, discard the whole field in moving scenes, but try to weave when they detect no motion...
a neverending game this is...
Old 26-11-2008, 12:15 PM   #15
2,383, Level: 11
Although I'm getting what it should do with 50i film, I'm not yet entirely on board with what it is doing wrongly.
(that'll be for my evening google session)
That BOB deinterlacing, is it exactly the same as in deinterlacing method C on this site Interlacing - Luke's Video Guide
So it is using this BOB deinterlacing on film AND on video? You say one whole field (out of 2) per frame is discarded, but going on the description on the aforementioned website, every field is stretched to fill up an entire frame (effectively doubling the framerate) thus not removing any fields.
EDIT: Oh, I think I got it. It throws aways 1 field of every frame when deinterlacing 50i film??
Old 26-11-2008, 12:44 PM   #16
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
I can't believe Pannies drop an entire field (in 2?) - wouldn't that create very jerky sports pictures? I've not noticed it.
And yes Jeroen, the term 3:2 cadence and 3:2 pulldown are talking about the same thing even though they don't actually have the same meaning.
Funnily enough detection of 3:2 cadence is supposed to be easier than 2:2, I suppose because you get a pattern where 2 fields are always identical and the next usually isn't.
Yes method C on that site is about right (but there are additional techniques to improve the results)
Old 26-11-2008, 12:52 PM   #17
2,383, Level: 11
Thanks Choddo. Now I can actually understand most reviews:-). I really like knowing what I was thinking of buying. I might be holding off for next year when the G12's arrive. My gf feels the Pio's are overpriced and I feel the Panasonic should just do a little better in that area. Might be checking out sharp and jvc now. Maybe there still is a middle ground.
We were intending to wacht digital tv (1080i) most of the time and unfortunately that's the area they are most weak in.
Old 26-11-2008, 2:29 PM   #18
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
Yeah - I have to say I don't think many people would be disappointed with the picture out of a PZ80 from a 1080i source
Old 26-11-2008, 7:39 PM   #19
5,698, Level: 17
Activity: 8.1%
They do on film sources! If you have StarWars: Attack of the Clones, Chapter 11 (I believe) you can check...horrendous stair-stepping...tried it on my JVC prog scan DVD recorder, forcing the film mode manually and it was correct then - smooth lines - perfect...however, the JVC also couldn't lock in AUTO mode and dropped the entire field...
Old 26-11-2008, 8:28 PM   #20
Conspicuous Member
choddo2006's Avatar
20,236, Level: 34
Activity: 0.7%
Yeah that's different than dropping 1/2 the fields with video content though, that's basically rough & ready bob deinterlacing (without dropping any fields) on a film source. Which TVs have you seen that on by the way? I thought Pannie's VReal3 was kinder to diagonals than that.
Old 27-11-2008, 10:16 AM   #21
10,814, Level: 24
Activity: 0.7%
Trusted Reviews just voted the 42PX80 best TV of the year (under £1000 category), so I'm not sure this a big problem.
I've watched 1080i HD film broadcasts and I havent noticed any problems. As HDTVTest said, with the quality of the broadcast signal you're not going to really notice it.
Old 06-12-2008, 9:38 AM   #22
5,698, Level: 17
Activity: 8.1%
choddo, I have the older PV70 but the same problem is also noticable on my Pioneer DVD player...I would expect with bob de-interlacing that, even though fields are line-doubled, when displayed in such a quick succession, they would blend and form a smooth and not stair-stepped result with film sources where there is no temporal displacement between fields... oh, damn, a 100 ways to complicate one's life...
anyway, here's a link to a forum where it's being discussed, with relevant pictures:
http://www.forum.hr/showthread.php?t=381745&page=11
Powered by
 Latest popular product prices
Samsung LE40D503
14 prices from
 £339.90 Click to show/hide the offers
Samsung PS43D450ZF
14 prices from
 £337.49 Click to show/hide the offers
Samsung PS43D490
12 prices from
 £398.39 Click to show/hide the offers
Panasonic Viera TX-P50C3B
11 prices from
 £399.00 Click to show/hide the offers
Panasonic Viera TX-P42U30B
6 prices from
 £399.97 Click to show/hide the offers
Panasonic Viera TX-P42ST30B
14 prices from
 £510.00 Click to show/hide the offers
Panasonic Viera TX-P42S30B
12 prices from
 £448.00 Click to show/hide the offers
Panasonic Viera TX-P42UT30B
5 prices from
 £449.99 Click to show/hide the offers
 Updated February 8th at 4:30am. Prices include delivery.
