Originally Posted by Panavision What about black levels? Which LCD is comparable to the Pio or the Pana? |
None.
They just aren't there yet. There is backlit led panels but they annoy me and the response time is delayed to process it, so not great if you like games.
There is a very fine line between accepable black levels and not, imho all the panny plasmas are the right side of that line, I have yet to see an LCD that is.
Something to mention here though, it really does depend on the viewing enviroment. During the day my Samsung 756 LCD actully looked like it had deeper blacks than the plasma, but as the night draws in and you start to have lamps on around the room that switches, the plasma looks darker than during the day and the LCD starts to show the glow from its screen on dark scenes.
That is all a case of how dark you can get the glass on the front, if you get a deep glass on the front you will get it to look darker with light in the room, however you have to drive the panel harder, this is why the new LCDs have contrast ratios of 70,000:1. Contrast ratio has nothing to do with black level, what we really need to see on the spec sheet is light output when showing black, although most of the LCDs dim the back light when there is alot of black on screen, so you get this fluctuating luminance all the time, which is another annoyance.
For me as long as I can get my screens blacks to go down below the point I find acceptable I don't worry about it, what I will say is only 2 screens that I have seen/owned have done this so far, the Pansonics and the Kuros.
Unfortunately, because they are so light sensative going into a store the darker glassed LCDs with there over driven white levels will trick you into thinking their blacks are better, and it is human nature to then seriously believe that your black levels are better than the plasmas as you saw it with your own eyes.
Same with sharpness and smoothness, LCDs in shops look like pixelated messes most of the time, as they are being overdriven, so the people who buy the plasma write them off.
The only way to tell is buy both and try both, keep the one you like best.
