Originally Posted by The Snake Basically, in the first few weeks just keep the screen brightness turned down until it 'warms up' and this will help the screen 'bed in' and reduce image retention problems. |
Contrast, brightness turned up will reduxe image retention.
I don't you have needed to worry about it for years now, maybe on crap screens but not on any of the main ones.
I left the Zelda start screen on for over 12 hours on my PHD8 when I got it and there was some retention, put the TV back on for an hour and when I checked it was gone.
Just set it up for a decent picture and you will be fine.
I think the whole 'which is better' debate is useless.
It really is a case now of which is better for you?
If you don't notice the Pioneer dancing pixels it is an awesome screen.
If you don't notice the noise on Panasonics in the dark areas that is an awesome screen.
If you can live with the black levels on the latest LCD's then they really do have a hell of a lot to offer over plasma.
Unfortunately demos in stores tell you nothing, 24 hours or 48 hours with a set also tell you nothing, you will either be diapointed or over the moon in the first couple of days, when you stop fiddling with the settings and just want to sit back and enjoy watching material rather than looking at the set itself is when you start to think if it is any good or not.
For me the real acid test is whether I want to adjust the settings as I switch between different sources and even different channels.
The only set I have owned so far that has not made me want to mess around constantly is the Panasonic PHD8. That doesn't make it the best set in any area, it just makes it the one I enjoy on a daily basis more. As a complete package it is almost perfect, if it were 1080p it would be perfect I guess.
