Bit of a bump
I have started infrequently using the front HDMI slot on mine, and have noticed it doesn't auto switch like the rear ones. Is this normal? I can only guess it is because of something along the lines of the front socket being used to hotswap stuff like camcorders etc?
It isn't the end of the world, I was just curious. Ta!
edit: I should add that I'm connecting devices that do auto-switch when connected to the back of the TV (a PS3 and Xbox 360) so it isn't the devices I'm using that are causing the issue - if indeed an issue exists.
