Originally Posted by red severn cal,d mine with spyder try these as approx settings i have expensive ref arcam dvd so get excellent results from ref patterns
cinema ,warm is correct colour temp you must have these settings for accurate colours.
if left of bar = 0 right= 100
contrast=70
brightness=48
colour=53
colour mangement=off
sharpness=personal taste
try some dark scenes to look at shadow detail you will see more info now ,i set all my sets using set up disks and they where all miles out with spyder it gives you pitures and explains what you should see before and after cal
hope this helps cheers red |
Ive been running these settings now for a few days and really like them, far better than my own settings i posted on this thread. Theres far better dark area detail now and more accurate colours IMO.
Going back to normal color temp now looks far too cool and green.
Regardless of values, normal picture mode seems to give a more contrasty picture with lower brightness levels and higher sharpness levels. It looks almost like an LCD to my eyes, although this mode gives a sharp/clear picture the dark area detail is poor and its hard to get the colours looking accurate.
Cinema mode appears to run less contrast, less sharpness and more brightness than normal mode at the same values, and accurate colours are more achiveable. I prefer this mode now with red severn's settings for dvd. blu-ray, general TV as it gives a realistic image IMO. However when viewing in the dark at night i often have to turn down the contrast to around 50% as it can be too bright.
For games though I prefer Normal mode still, as it gives a cleaner, sharper picture, however for games with lots of dark areas like Gears of War, Cinema comes into its own thanks to the better dark area detail. One thing that does annoy me sometimes is that i notice the black level can fluctuate depending on the scene, i notice this on GT HD on PS3 when I enter the tunnel, if i park the car at first it appears dark then after a few seconds i can see the the black level automatically begin to light up.
Also when gaming i feel less need to use warm colour temp. Studio and movie cameras maybe calib'd at D65 6500k as there capturing real life, but I doubt video game colour pallettes are designed with this standard in mind.
