I posted back on page 4 on 13 11 2007 but only got my Philips 42 9944/01S fixed recently.
The faulty component was part number 2540, a 100 uf electrolytic capacitor associated with part number 7540, a positive voltage regulator L7805 on the power supply board FM24.
Groundhog posted on 12 12 07 that he had read that someone was getting his screen to start by blowing hot air over the circuit board from a hair dryer. I had noticed that the relays would lock in quicker when the screen had been running and was hot and when cooled down it wouldn’t. (If starting from “off” there was a period of silence until, gradually, a faint clicking of relays would be heard and build up to full clicking – so don’t give up if you get total silence! )
I tried with a hot air gun for paint stripping and found if reasonably close to the area below and left of the blue rectangular relays it would start straight away.
With the help of a friend with electronic design experience we tested all the components around the area by applying a hot soldering iron to them. Apparently transistors and capacitors will withstand temperature of 100C for 1 to 2 secs without damage (I wouldn’t have risked it without advice). Heat a component, switch on, if your lucky it clicks in straight away. Quite a moment!
IMPORTANT. Each heated component has to cool down again before testing the next to avoid confusion.
Replacing components on these boards is tricky. If you are not skilled I suggest you do some tests, identify suspect, and then seek someone with experience to actually fit the components for you. I know, but if you overheat the boards the foil tracks will come away and then you have more problems.
My friends says these aluminium electrolytics are not top quality and if they were a dodgy batch (we’re all suffering with these faults) 5 years may be all they can manage.
I hope this helps. It certainly was a relief to get my screen working reliably again. I paid £3700 for it 5½ years ago. I looked at current plasmas around £1K and the Viera looked pretty good but the picture is very processed compared to my old Phillips. (I feed it with SKY HD and HD discs converting HDMI to VGA using a Vision FC4 converter from Lektropacks .
http://www.lektropacks.com/view_prod...ub1=65&show=65
Even 576p looks great. I have a projector as well).
Good luck. Questions? Try me, I can alway ask my friend!
