what is a common interface slot ?
Old 04-09-2006, 1:51 PM   #1
DUVET's Avatar
Thanks: Gave 23, Got 1
what is a common interface slot ? and whats it doing on a plasma ?
answers on a postcard please.
or
post below.
cheers
Old 05-09-2006, 12:44 AM   #2
stainway's Avatar
Thanks: Gave 20, Got 130
Re: what is a common interface slot ?
From Wikipedia:
"The Common Interface (CI) is the slot on a digital television receiver into which a conditional access module (CAM) may be inserted for satellite television. Receivers normally have two common interfaces. A receiver with a common interface allows the user to access encrypted television broadcasts as opposed to free-to-air (FTA) channels."
You can use your Common Interface (CI) in combination with Conditional Access Module (CAM) and get some extra channels on top of the existing free-to-view Freeview channels:
http://www.radioandtelly.co.uk/topuptv.html
Old 05-09-2006, 9:11 AM   #3
DUVET's Avatar
cheers for that, just wanted to know what it was.
so its something i will never use !
Old 05-09-2006, 10:11 AM   #4
Thanks: Gave 58, Got 15
I use mine for TopUpTV via a CAM.
K.
