Is there a link to watch it now as fell asleep last night
Is there a written summary?
More later, but you have to see them side by side set up properly. The difference is how the sets hang on to black vs ambient light.
When a set holds black better it does not need to go as bright.
Just because an image is brighter does not mean you can see it better in a bright room, if light pollution washes out the the image because the panel absorbs the light due to a poor filter then the extra light is pointless.
A GT goes much brighter that a VT and a ZT but but you will see more picture detail and contrast on a VT and even more on a ZT.
This is my 55VT50 in a brightish room, about to take it down and it will be up for sale in the classifieds.
I now have a 55VT65, and will be using it until my ZT arrives.
I have now calibrated 10 VT65's and not experienced any of the issues reported in the states. But non of the sets in the TPS showroom have shifted.
I'm going to calibrate this VT65 out of the box and take measurements every 50 hours in my real home environment to see for sure how it behaves.
View attachment 395987View attachment 395988
I see that but that's a live feed is there any links to watch last nights events ?
Interesting to read the results from two K10s and David's opinion on comparing mll readings from different sources.
I assume you mean the level of ambient light affects the reading?Its more the environment(s) that are the deciding factor as the k10s are very consistent.
Yeah, the difference in the two rooms I use for TV downstairs is only very small but I do get lower readings in one so I always put them in there for those measurements. Steve seems to regularly get slightly lower readings than other reviewers using a k10 but he has a completely light controlled home theatre, which I'm sure explains it.
Could you not use some sort of cape/shroud thing covering the TV?
Also, when you do measurements, do you (or does the software) turn your computer display off?
Richer sounds are having a open day and comparing zt vs vt vs kuro all calibrated like the tps meet.
Calibrated ZT vs VT vs F8500 vs Kuro Shootout in Leicester
Talk about trying to get in thier before the tps meet.
I had posted about this before in the "Kuro vs Modern plasma" thread as Richer Sounds had put a thread on here about it, but it got deleted for some reason? (Scooby won't say why) But with no disrespect to TPS, I don't think a national chain like Richer Sounds care what show a 1-off independent retailer does in terms of a 'shootout'
But with ******** calibrating the TV's for the TPS meet, and David MacKenzie doing it for the RS meet one thing is for sure... a lot of people are in for a treat looking at the VT65 & ZT65 and are going to be torn between the 2 (knew I could get this back on topic )
That is just nonsense.
What is the meet or trying to get one organised before tps meet. I am just pointing out the facts at the end of the day just an event for users to check out the panels for them self that have been calibrated.
Rs is trying to ground them selves in like tps on the forum but IMHO not all their sale staff are not knowledgeable about the items they sell and try a more harder sales tactics. As I found out recently when trying to get my 55 vt65.
I have bought from them in the past but depends which shop you go into, I have 3 that's are not too far from me.
