Hi folks
Hoping somebody can help me here with a little issue. I have a 51 with a very simple setup of HDMI 1 running into a Denon AVR 1910. from the denon I have my Sky, Dune, DVD, PS3 etc
Everything works fine through the day with devices switching on and off via the TV but fails to switch on correctly in the morning?
First thing in the morning the routine is generally switch on the Sky box from sleep then switch on the TV via the remote. This is where th problem starts with the TV reporting No signal
To resolve the Denon needs to be switched on and off again once the Sky signal is visible. After this all is well
This was not an issue previously with my old TV which was a 5yr 37 LG LCD
Firmware 001021
Only alternative that I can see at the moment is to run Sky directly into another HDMI but would rather retain the ability to run audio through the Denon
Thanks in advance
Ste
