Originally Posted by stucarblne That's unfortunate. I know how it feels though, but for a different issue.
My one was red tinted black which was due to out of spec voltage and complete and utter denial from the manufacturer. With me having to reset my panel to trick it into thinking it is new then re-adjusting and battling mal-discharge.
Will probably be nursing it with voltage tweaks for the rest of it's days. But i might be lucky, only time will tell after my most recent ones, but they looking good  |
You got a LG too then? And if so...exact same model? :D
I also believe that..the bigger the screen, and i consider 60 biiiiiiiiiiig, the more easier you will notice faults. If this screen had been say...42 or even 50 inch. I think it would be harder to notice. A big screen is awesome, but it will also clearly display faults in games more noticeable. Like bad framerates are much worse on a huge tv than a small tv, on small tv alot less noticeable.
I've always believed that my very first plasma, Samsung PS50C91 was without faults, but at that time i probably didn't notice them. After the Panasonic VT30 fiasco however, i look at tv's in a different way and spot faults quite easily unfortunetely. But i think i can live with this, it still sucks that a skyline in a game like Max Payne 3 and Skyrim can't simply look completely like it should, without any lines or whatsoever, but it's not like i have much other options. I could bring the tv back and go for the Samsung E6500, but that's a 51 inch, quite a difference and also much more money. Nah i'm gonna accept this as long as it won't get worse.
And i hope it won't. I remember when i had just bought this tv, i don't think i saw any of that green stuff yet, and then it started to appear. So i hope all will be fine now. Have had more than enough tv problems i'd say.
