samsung PS51D495 plasma-what are the best settings to use
Old 12-02-2012, 8:02 PM   #1
hello,has anyone got one of these sammys,and if so what do you think are the best settings are for tv.thank you
Old 25-02-2012, 8:46 AM   #2
Limited Member
Thanks: Gave 4, Got 1
I would also like to know this, just got the set yesterday
Old 25-02-2012, 9:11 AM   #3
Thanks: Gave 191, Got 369
Movie and Warm2 will be a good starting point,then set the brightness,contrast,colour and sharpness using test patterns available on some THX dvds,DVE,Spears & Munsil or free download AVS rec 709 there are also some test patterns on Sony Pictures Blu Ray accessed by entering 7669 when on the menu screen.
You can aslo try settings from other D series plasmas.
Regards Martin
Old 25-02-2012, 5:22 PM   #4
Thanks: Gave 1,854, Got 4,215
It should work fine out of the box.
If you don't like the way it looks after a day or two change the settings until you do like it - nobody else's settings would necessarily be right for that.
