| Quick Question about Self Calibration
After placing my cheap and cheerful PC monitor next to my VT30, I could see the vast difference between the good color representation on the monitor, and the truly awful results on the TV. Even the THX and standard PRO settings were overly saturated by some colour, and were crushing blacks badly. I was thinking about sending this one back as it looks exactly the same as my last faulty unit, but not quite so severe.
Because I had a point of reference, I decided to change some of the more detailed RGB settings in the PRO1 profile.
I don't really understand how I did it but I made the problem with the TV almost go away, but now I'd like to get it calibrated properly, because I'm sure I only got half way towards doing it right. To me the picture is watchable again, but I'd like to go the whole hog ang get it near perfect.
So I would like to buy an X-Rite i1 Display 2, and probably use Calman's 4.x software to perform an auto calibration, since it supports a direct connection to the TV over IP.
I have found a 'new' Pantone Eye One Display 2, and I understand Pantone has been acquired by X-Rite. Does this mean that what I am intending to buy is exactly the the same as an X-Rite unit? Could the unit I'm buying be a few years old, albeit new but possibly it's calibration may have drifted a little while it's been sat on the shelf? The physical devices look identical to each other, so I'm assuming there's just been a re brand. The Pantone unit is brand new and sealed however.
MR
