Pioneer KURO 9G Owners Thread part 13
Thread Closed
Old 05-08-2012, 9:08 PM   #841
jason1wood's Avatar
Thanks: Gave 59, Got 133
Cheers lads. All sorted. Cracking pic now.
Old 08-08-2012, 2:47 PM   #842
stucarblne's Avatar
Thanks: Gave 717, Got 266
@ Shagger
Shagger did you hear anymore from your mate with his Kuro and his Darbee ?...
I'm definitely going to buy one soon. Just can't make up my mind if i want to integrate it with the Lumi when i get that too or keep it just for gaming.
Old 08-08-2012, 2:54 PM   #843
aandpwoodley's Avatar
Thanks: Gave 326, Got 440
Originally Posted by stucarblne View Post
@ Shagger
If yu get a lumagen you won't need the Darbee in my opinion
Old 08-08-2012, 3:04 PM   #844
KuroMike's Avatar
Thanks: Gave 13, Got 25
Hi Guys
I haven't posted in a while but just wanted to pick your brains on a small something.
The KRP600A that I have recently got got makes quite a lot of little clicks and popping noises from round the back of the TV - they sound like static. I have been advised that they are due to the tv heating up and plastic etc expanding in the heat. The TV will do this regularly for a long time, perhaps an hour or so, then it seems to settle down. It can be quite annoying.
I have had a Pioneer service centre out and they have taken the back panel off and tightened everything up but the TV still does it. It did improve things a little bit. Has anybody else got a TV that does this? My old LX5090 did not do it.
The TV has had a small voltage adjustment to RST-P to drop the MLL - this could not have any effect on the TV to cause this could it? Wouldn't cause the TV to run hotter or anything like that would it?
Any suggestions on how to cure it? The Pio call out/work has cost me £100 and I was really hoping it would rid me of it but to no avail. The engineer who called out had not seen this issue before.
Apart from that - the TV is bl@@dy fantastic!
Cheers.
Mike.
Old 08-08-2012, 3:04 PM   #845
Thanks: Gave 810, Got 198
@ Shagger
he told me stu that his picture has more depth and is clearer lol his words in a text message, his screen is uncalibrated, so to me maybe he would of been better to spend the money on a calibration and not the darbee
stucarblne (08-08-2012)
Old 08-08-2012, 3:58 PM   #846
stucarblne's Avatar
Mike if anything it would make it run cooler. Played a lot with RST P, and the higher the number the more it buzzes. Not clicking or creaking though
Old 08-08-2012, 4:05 PM   #847
KuroMike's Avatar
Hi Stu
Thanks for the reply.
Must be one of them things with the TV. If anyone else has got any theories, please let me know.
The Olympics has been looking amazing on it!
Cheers.
Mike.
Old 08-08-2012, 4:27 PM   #848
stucarblne's Avatar
Originally Posted by KuroMike
Hi Stu
Cheers.
Mike.
Hi again Mike.
Thinking again it could be the power supply unit, not necessarily faulty though. I haven't spent any longer than 20 minutes with a 60" 9G, and that was in a demo room with surround speakers on, so unable to properly comment on that. Does it come from the middle back ?, assuming the power supply unit is in roughly the same position as the 50"
Old 08-08-2012, 4:33 PM   #849
KuroMike's Avatar
Hi Stu
No it comes from all over the back of the panel, not just from one point. Pio service guy said everything was working fine.
It is a click here and there at dfferent pitches. Sometimes they are close together. Then it settles down once the TV has been on a while. The occasional one is quite loud. I sit 14 feet away from the TV and can clearly hear the loud ones.
Cheers.
Mike.
Old 08-08-2012, 5:34 PM   #850
Originally Posted by KuroMike View Post
Hi Stu
Cheers.
Mike.
everything is fine, surely as you have had it checked out, just watch it and enjoy
Old 08-08-2012, 5:46 PM   #851
Insanity202's Avatar
Thanks: Gave 5,528, Got 3,131
Originally Posted by SHAGGER
or bumtious
Or Bumtious@TPS
middleweight (08-08-2012)
Old 08-08-2012, 5:55 PM   #852
stucarblne's Avatar
I understand what you are trying to say. But i think for such a low price as that, that it would be worth my while buying one anyway. I wont have the lumagen for about 3 months yet, and this within the next month. And if i prefer the ISF'd KRP with the calibrated reference Lumagen on their own - well i have still got the Darbee for less capable equipment, but i will try it on it's own with the Kuro first - then all three. I am going to buy a cheaper 2nd hand 50"plasma for round about the £500 mark early in the new year for the front room, and it may come in handy.
Old 08-08-2012, 7:27 PM   #853
KuroMike's Avatar
Hi Shagger
Just put the Tv on and I'm sat here listening to it click every 10 seconds or so at the moment. Seems a bit worse tonight. It's one of those things that once you hear it, you are sat there listening for it. If you can hear it from 14 feet away with the volume on normal on the TV then you wonder if there is a fault with the set.
Just like when you spot the red tint - lol
Old 08-08-2012, 7:36 PM   #854
Hi Shagger
Record it & upload to you tube, we can then have a listen to it
Old 08-08-2012, 7:50 PM   #855
stucarblne's Avatar
Make sure and keep the volume down if he does - it might knacker your ear drums ! ; )
Old 08-08-2012, 10:32 PM   #856
Hi Shagger
never seen red tint, so can't comment, if you think its faulty, scrap it, go to tps buy a vt and a lumi
Old 08-08-2012, 11:17 PM   #857
KuroMike's Avatar
I don't think its faulty, I just think its one of them things. Picture is breathtaking though.
Always loved my lx5090h but the extra screen size of this KRP means I can never go smaller now. So have you go a spare £5000 to lend me for a 65" VT50 and a Lumigen to get a picture that is equal to what I've already got? ;-)
stucarblne (09-08-2012)
Old 08-08-2012, 11:22 PM   #858
on a serious note mike, im sure your krp is fine,
Old 08-08-2012, 11:34 PM   #859
KuroMike's Avatar
Hi Shagger
Thanks mate. I'm sure too. It is just a bit annoying.
It has to be something inside heating up an expanding. I've just switched the set off about 10 mins ago and the clicks started up again after the set was off almost like stuff cooling and returning back.
I think the only thing the Pio service centre could do now is to take it in and completely disassemble it! Ha would be very expensive and I'd probably lose all my ISF Night settings. I ain't doing that
Old 08-08-2012, 11:44 PM   #860
Hi Shagger
just turned mine off and it clicks, exactly that cooling down,
Old 09-08-2012, 12:12 AM   #861
stucarblne's Avatar
Yeah Mike chances are it's just the bigger size of the screen overall = louder sounds with more heat etc. It's probably to be expected.
middleweight (09-08-2012)
Old 12-08-2012, 2:35 PM   #862
stucarblne's Avatar
Anyone with a 9G tried playing PS3 or 360 with Pure Cinema activated on "smooth". I remember reading somewhere ages ago now that this might actually work whilst gaming...
I have tried it on game AV mode with NFS Hot Pursuit, Metro 2033 quickly but can't make up my mind if it looks better or not. Or if it just looks too processed. Also i don't remember if this was suggested with Game control Pref to be on or off ?
Old 12-08-2012, 3:57 PM   #863
Assured Advertiser
Bumtious @ TPS's Avatar
Thanks: Gave 207, Got 3,607
Smooth does not work.
It's a frame interpolation and a badly implemented one. It causes tearing and stuttering if movement is quicker than the processing can handle.
Like a couple of things in the menu descriptions on these sets, what it does has been lost in translation.
www.tps.uk.com - 0161 344 0123 Mon-Sat 10am-5pm TPS is proud to be supporting AVForums as an Assured Advertiser
TPS AVFORUM product information thread
ISF Certified Calibrator Level I & II Call 07540 691636 for detailed information
stucarblne (12-08-2012)
Old 12-08-2012, 8:39 PM   #864
Thanks: Gave 48, Got 53
Hi fellas, (mostly) happy new Kuro owner here. I bought my LX5090 in May, and was all set for the olympics - when suddenly, the digital tuner would start resetting the TV channel memory every time I turned the set off. I tried rescanning a few times, but after turning the set off an on again - poof. All channels gone. The tv goes straight into setup, when selecting aerial/tv as the input source.
2 weeks ago, things got worse. I now cannot even get a tv signal anymore - I tried running a signal test from the TV's menu, but no luck. And no signal.
It sounds to me like a busted tuner, but will this be covered by the extended warranty? I had it transferred to me, when I bought the TV...
Old 12-08-2012, 8:51 PM   #865
KuroMike's Avatar
Hi all
Anyone on here with a KRP or LXH use the built in satelitte receiver?
I've just noticed that my BBCHD and BBC1HD have vanished and no matter how many times I rescan, I can't find them. Still got ITVHD and C4HD, but the two beebs have gone. Bloody typical as the Olympics has looked stunning.
I'm used to channels disapearing but I've always managed to find them again after rescanning.
Cheers.
Old 13-08-2012, 7:50 AM   #866
Kev12's Avatar
Thanks: Gave 227, Got 313
That's what the warranty's for, call Pioneer.
Old 13-08-2012, 11:08 AM   #867
stucarblne's Avatar
Hi all
Cheers.
Hi Mike,
Have you phoned Pio to see if there is any recent updates available ?
Old 13-08-2012, 6:03 PM   #868
KuroMike's Avatar
Hi Stu
I have contacted Pio before and they just recommend rescanning. Had to watch the end of the Olympics in standard def - tell you what though, the KRP still did a damn fine job of showing that on a 60" screen!
stucarblne (14-08-2012)
Old 14-08-2012, 1:17 PM   #869
stucarblne's Avatar
Hi Stu
Any luck with the rescanning Mike ?
Old 14-08-2012, 1:31 PM   #870
KuroMike's Avatar
Been rescanning every night - no sign of them yet, mate.
It's not the end of the world as I've still got ITVHD and C4HD.
Hopefully they'll just pop up again at some point :-)
Thread Closed
