3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > Plasma Televisions
Today's price checkPowered by
Panasonic Viera TX-P42G10E
Panasonic Viera TX-P50G10E
Samsung PS-42B430
Panasonic Viera TX-P37X10E
Samsung PS-42B430
LG 50PS3000
Panasonic Viera TX-P42V10E
Panasonic Viera TX-P42X10E
LG 60PS7000
Panasonic Viera TX-P50X10
Panasonic Viera TX-P50V10E
 More...Prices updated November 8th at 4:30pm and include delivery.
SAMSUNG LE40A556P 40: any better recommendations OM2 Which LCD TV Should I Buy? 11 16-03-2009 10:51 PM
Wii hookup with Onkyo 705 & Samsung 850 LCD. Freddy2 Wii 6 08-01-2009 12:07 PM
HDMI and separate audio? pjhepworth AV Amplifiers and Receivers 5 07-01-2009 1:33 PM
Samsung LE408686 white interference lines solarfusion LCD Televisions 0 07-01-2009 12:21 PM
Old 07-01-2009, 1:01 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Samsung PS50A557S3FXXU audio - bass
We have just taken delivery of a Samsung PS50A557S3FXXU plasma and are very pleased with the picture, but the speakers seem very, very weak. The sound is crisp and clear I suppose, but there is very, very little bass component. It sounds to me as if only tweeters were running and woofers were not. I have been into the sound settings and have it set to custom, with a high gain on the low end of the 5-band equaliser, but the bass is still very poor. It is bad enough that I can have problems understanding speech because there is no real timbre to the voices.
As this is our first flat or thin TV I don't know what to expect. Can someone tell me, is this quality of audio to be expected from modern sets? Are you expected to buy external speakers? Is this a consequence of the lack of a big box to resonate in?
Also, there is a flashing green light on a PCB within the rear of the set. Is this normal? Manual does not mention it.
Thanks,
Chandy
Chandy is offline   Reply With Quote
Old 07-01-2009, 2:10 PM   #2 (permalink)
Re: Samsung PS50A557S3FXXU audio - bass
Admins, should this be moved to Samsung PS50A556/557/558/S Owners Thread
Ah wait, that post is closed, nvm.
Old 07-01-2009, 6:45 PM   #3 (permalink)
kjt2004's Avatar
Thanks: Gave 40, Got 179
Im afraid it is a trait of the samsung having weak audio because of the speaker used to get inside the bezel
A quick fix and one i use is to hook up a cheap2,1 pc speaker set via the 3.5mm headphone jack at around £25 from pc world or similar
Drastically improves the sound and the volume on the remote controls the volume
regards
PS42C96HDX:Digifusion160PVR:Oppo 971H DVD: Sony Dav S550 ,AE2 Fronts,M A Radius R270 Sats +Canton CD50 centre. Pics below
http://www.avforums.com/forums/showp...postcount=6538
http://www.avforums.com/forums/showp...postcount=5034
kjt2004 is offline   Reply With Quote
Chandy (08-01-2009)
Old 07-01-2009, 7:56 PM   #4 (permalink)
Thanks: Gave 52, Got 365
Also, the most efficient way to get the speakers to sound bassier (without upgrading, of course) is to reduce the treble and increase the overall volume.
YellowSphere is online now   Reply With Quote
Chandy (08-01-2009)
Old 08-01-2009, 11:25 AM   #5 (permalink)
@kjt2004 + @YellowSphere.
Thanks guys, both very good tips! I changed to 'music' setting for audio and then upped bass and dropped treble from there and now it sounds a lot better. Going to look at PC speakers too.
Chandy
audio, bass, ps50a557s3fxxu, pss3fxxu, samsung, speakers
