grepmonkey
- Joined
- Dec 1, 2008
- Messages
- 2
- Reaction score
- 0
- Points
- 2
I have a new 5090, 2 weeks old. Its been great, but yesterday the status light was blinking (blue).
I powered off TV waited a minute (as per the manual) and it all came on again ok.
10 mins later I noticed a series of diagonal white pixels across the screen ,hard to spot unless there is a lot of dark on the screen. If I stick the TV on standby after about 5 seconds the red status light goes blue and starts blinking. I can clear it by powering off the set again.
This is now happening constantly. I have noticed that if I get the home menu up the diagonal lines go again for a few minutes then return.
If I take the plug out and wait a couple of minutes same results - but the problem comes back.
Does anyone have any ideas? Have I setsomething somewhere I shouldnt have?
This happens regardless of input - sky (scart) or ps3 (HDMI) or the digital tuner.
Can anyone suggest any thing - or can I run any diagnostics?
