AVForums.com twitter AVForums reviewers are ISF Certified.  Click for more information. AVForums is a member of CEDIA.
AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > Plasma Televisions
Notices
Do all 1080p LCDs give 1x1 pixel mapping? MrHiggy LCD Televisions 1 11-07-2008 5:39 PM
32" 1080p LCD with 1:1 pixel Mapping For PC use ?? lbbuk Which LCD TV Should I Buy? 9 01-07-2008 2:07 PM
Does VGA input garuntee pixel for pixel mapping from a pc ? lambert LCD Televisions 18 01-01-2007 8:09 PM
Panasonic AX100, HTPC and 1:1 pixel mapping Alister Willis DLP, LCD and D-ILA Projectors 1 13-11-2006 10:05 AM
List of LCD TVs with 1:1 pixel mapping from HTPC gr8r LCD Televisions 11 09-08-2006 8:11 PM
Old 24-11-2008, 10:40 PM   #1 (permalink)
Thanks: Gave 8, Got 0
Smallest best 1080p Plasma with 1:1 pixel mapping for my new HTPC
I have a Pioneer 4280xd which im considering selling as im building a new htpc. I read the pioneer isnt the best in this respect. I plan on using media centre or portal with a new htpc im building and feeding it with freesat and building a library of hd videos mkc files etc. Also I live in a 2 up 2 down, so my living room is relatively small so I may even consider down sizing - I found the pioneer to be fairly dominant and perhaps even overpowering in the room. Anyway what are your thoughts? Im thinking of possibly heading down the Panasonic route.
dannyb666 is offline   Reply With Quote
Old 24-11-2008, 11:17 PM   #2 (permalink)
choddo2006's Avatar
Thanks: Gave 251, Got 490
Re: Smallest best 1080p Plasma with 1:1 pixel mapping for my new HTPC
I don't think that would be any problem on the 4280
choddo2006 is offline   Reply With Quote
Old 25-11-2008, 8:45 AM   #3 (permalink)
gizlaroc's Avatar
Thanks: Gave 48, Got 287
Pansonic PF11 will allow you to turn off all scaling making pixel mapping nice and easy.
Kuro black levels, so Panasonic say, and they look nice and neat too.
No Darling.......I've had it for months
gizlaroc is offline   Reply With Quote
Old 25-11-2008, 9:13 AM   #4 (permalink)
Thanks: Gave 28, Got 401
42" is the smallest 1080p plasma and they are all made by Panasonic. They all do 1:1 mapping. But why not keep the Pioneer. I'm sure lots of PC users have it.
rewerb is offline   Reply With Quote
Old 25-11-2008, 12:20 PM   #5 (permalink)
Assured Advertiser
Liam @ Prog AV's Avatar
Thanks: Gave 3, Got 620
The 4280 isn't 1080p, it is 1024x768 using rectangular pixels and so you get a stretchy desktop made up of only about a third of the number of pixels the 42PF11 uses. It also only accepts the signal via VGA at 60Hz, where the Panasonic being 1080p will accept 1080p24, 50 and 60 all with 1:1. The 42PF11 is the best 42" display on the market at the moment IMO.
call me: 01892 860801 / e-mail me: liam@progressive-av.com
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Liam @ Prog AV is offline   Reply With Quote
Old 25-11-2008, 12:47 PM   #6 (permalink)
Nothing to add from the TV side, but just wanted to suggest Boxee as a suitable front end for your HTPC. It runs on a variety of platforms, I personally use it on my AppleTV and am very impressed.
djhomeless is offline   Reply With Quote
1080p, htpc, mapping, pixel, plasma, smallest
