09-11-2008, 10:36 PM
#1 (permalink)
Thanks: Gave 1, Got 0
Plasma for £1500 budget
After initially looking for an LCD TV, I nearly settled on the 9 series from Samsung or the Sony W4500 but each had there downside. I currently have a 3 year old 42" Philips Plasma but feel it is time to upgrade, lack of HDMI etc being the main reason.
I will mainly be using it for gaming and streaming from my Popcorn Hour A110 and was put off with the lag issue on the Sammy LCD and the clouding issue on the Sony.
So, my question is, can I buy a Plasma that will tick all the boxes for a £1500 budget. Needs to be >46".
Much appreciated.
09-11-2008, 10:46 PM
#2 (permalink)
Thanks: Gave 132, Got 211
Re: Plasma for £1500 budget
[Sources] Kuro LX5090 < Pace Sky+ HD 1TB / Toshiba XE-1 / PS3 slim / Marantz CD63
[Audio] Yamaha E800 + Lyngdorf SDAi2175 -> ATC SCM12 (Stereo) + MA B2 (rears) + BFD -> BK Monolith DF
[Headphone Setup] Emu 0404 +mods > Millet MAX > Grado HF-1 / Senn HD25-1 II
09-11-2008, 11:08 PM
#3 (permalink)
Wow, thanks for the quick reply.
I am going to look around for some reviews on this set as I really like Pioneer but thought it would be well out of my budget.
Many thanks.
09-11-2008, 11:15 PM
#4 (permalink)
Ah, was looking for a 1080p set.
I did read the thread regarding HD ready v Full HD but as I am upgrading from a HD ready Plasma, I would prefer to go Full HD.
10-11-2008, 9:39 AM
#5 (permalink)
Hehe I stuck with a quick reply and not much detail.
I would say try to forget about the FULL vs READY unless you will be using the screen for heavy pc monitor usage, or sitting within about 7ft. The difference really is soo smal, and as I normally put it, just the cherry on the cake. Does the cherry sway the decision over which cake you buy or reflect the quality, e.g. buy a taste the difference cake without a cherry on top, or a sainsburys basics one with a cherry. Which will be the better buy and please you more ?
I did some comparisons at TLC broadcast where Tony actually asked me to point out which pioneer was which (comparing the 508XD and the 1080p LX508). With both running casino royale on blu ray I couldn't tell the difference until a shot without movement came on, but was still not 100% sure. When I put on starship troopers I started to see it more, but I was still having to look hard and only really first saw it when I was about 5ft from the sets. At my normal 10ft watching distance it was nigh on impossible to see. Plus I have 6/4 vision with my contacts which is better than most peoples 20/20.
Hope that helps a little in explaining the picture quality is not governed by the number of pixels on screen, the 8G non-1080p pionners are still better than any LCD I have seen, and better than every panasonic plasma out there, which I regard as the 2nd best brand of plasmas.
10-11-2008, 12:21 PM
#6 (permalink)
Thnx for the reply.
I guess it comes down to ensuring (as much as I can) that it is future proof.
I sit approx 14ft away so i guess it would not be too much of an issue but I think the fact that there was an affordable 1080p out there means that i will forever be 'kicking' myself and wondering.
I have swayed back to the samsung 1080 8 or 9 series as people are now saying that input lag is fine.
Decisions decisions...
to be continued.
10-11-2008, 12:26 PM
#7 (permalink)
Why use the word futureproof if you won't be able to tell the difference between 720p and 1080p at 14ft now, or in 20 years time unless using special super cyber eyes or a pair of binoculars.
But the picture from the pioneer will be better than those samsungs screens. Just consider what is better, being able to tell people that your tv is 1080p and you can't even see it, or being happy with a better built, more reliable, and most importantly a superior picture quality to savour for many years to come.
I would say that a lot of things posted in the LCD forum are based on people loving the set they purchased and not actually properly comparing sets when demoing. A lot of time it is people pimping their own tv, and anyone who suggests it isn't the best set in the world is put down as either a plasma fanboi or someone who doesn't have a clue
Just have a look through the forums, and in the LCD section samsung owners threads are plagued with people seeking help on how to solve problems with the sets that are flawed from the factory, and discussing which new iteration firmware to install in order to attempt to cure said problem. In the pioneer threads the most heated points are the appauling manual, and inability of most of us to understand which drive mode to put it in
10-11-2008, 12:45 PM
#8 (permalink)
Thanks: Gave 137, Got 121
agreed i would also stay away from the sammys, if u want the 1080p aspect, and cant afford a pioneer to do it, then i strongly recommend a panny.
they are the 2nd best plasma out there, so bang for buck they are well worth it, no problems with IR or screen burn, use mine for SD,HD, bluray, HDDVD and PS3, even after about 5hrs of GTA4, there was no problems with IR or burn.
Panasonic TH-50PZ70, Toshiba EP30, Sky +, Onkyo TX-SR577, PS3 PSN systemdemon, 1 wife, 2 kids(boys), 1 alsation(german shepard), 1 weimaraner and 1 cat(Mr. Bigglesworth  )
"It's a pity you Autobots DIE so easily, or I might have a sense of satisfaction!" 360SelfRepaired!
10-11-2008, 7:07 PM
#9 (permalink)
Thanks: Gave 196, Got 96
My 508xd displays blurays better than a 42 inch full hd pana. Although i have not been able to compare the same size screen. I'd buy the 5080xd, superb tv.
Music:- Linn Ninkas, Linn lk85, Two Linn lk140, Linn Karin, Linn Genki. RA Torlyte rack,RA reference/signature powerkords,RA mains block/megaclamp,Kimber silverstreak IC's,Kimber 4tc/8tc.Cinema:- Pioneer KRP500A,Pioneer BD51,Onkyo 605,Mission Mcube 5.1,SkyHD,Xbox360,Mark Grant cables.
10-11-2008, 7:10 PM
#10 (permalink)
By the way, i'm 14 feet away from my 508 and it looks superb. I still don't like lcd and my mate has just had a clouding issue on a 10 month old bravia. They just don't look natural to me.
10-11-2008, 7:16 PM
#11 (permalink)
Thanks: Gave 69, Got 162
To compare the Pioneer with a Sammy LCD is like comparing a Ferrari to a Ford Fiesta.Never mind the lack of 1080p, it would be an expensive mistake to ignore the Pioneer in favour of a Samsung LCD.
Get busy living or get busy dying
10-11-2008, 7:23 PM
#12 (permalink)
Cheers one and all.
I have set my sites even higher and am looking at the KURO LX5090 now.
I think that this is finally going to be the screen for me. I have a 42" Philips just now and although a bit dated, it has never let me down.
So, the Plasma v LCD fight has been well and truly won by the Plasma.
Now to count my pennies.
10-11-2008, 7:33 PM
#13 (permalink)
Cheers one and all.
Good decision
11-11-2008, 10:04 AM
#14 (permalink)
Thanks: Gave 33, Got 18
I would still think the 50pz800 is worth a look at if found at a good price and I think its available in 46" screen size also.
Panasonic TH50PZ800B / TH50PZ800 Review
Pioneer KRP-500M plasma-samsung bd-2500 black-Onkyo tx-sr876 a/v receiver-Lumagen HDQ scaler -marantz pm7001 ki sig. amp-marantz cd6000 ki sig.-Tannoy DC1 sensys main speakers-se24 atacama stands-tannoy sensys centre spkr-tannoy sensys R rears,Russ Andrews Powerblok.
11-11-2008, 10:44 AM
#15 (permalink)
Thanks: Gave 38, Got 622
Sorry, no 46" version. 42,50,58,65..
