AVForums - Free Audio Visual electronics advice and information
AVForums.com twitter page AVForums.com facebook page AVForums is a member of CEDIA. THX certified reviewer.  Click for more information. AVForums reviewers are ISF Certified.  Click for more information.
Forum List Register Blogs Information Social Groups Search Today's Posts Mark Forums Read
Go Back   AVForums.com > Forums > Video Electronics > TVs > Plasma TVs
Latest popular product pricesPowered by
Panasonic Viera TX-P42G20E
Samsung PS42C450
LG 42PJ350
LG 50PK350
Samsung PS42C450
LG 42PJ350
LG 50PK350
Samsung PS50C450
LG 50PK590
Panasonic Viera TX-P50VT20E
Panasonic Viera TX-P42S20E
Panasonic Viera TX-P42X20
Panasonic Viera TX-P50X20
 More...Prices updated July 30th at 12:30pm and include delivery.
LinkBack Thread Tools
Old 12-09-2008, 3:38 PM   #1
Thanks: Gave 1, Got 1
Difference between 24p Real Cinema AND 24p playback
just wondering whats the REAL difference between
- 24p real cinema (found on the TH-46PZ85)
and
- 24p playback (found on the TH-46PZ80)
is there any difference ?
because both models don't have both features.
thanks.
SPiET is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookShare on Twitter
Old 12-09-2008, 6:30 PM   #2
Thanks: Gave 13, Got 0
Re: Difference between 24p Real Cinema AND 24p playback
and
thanks.
24p real cinema ties in with the Intelligent Frame Creation. The 'standard' that most people look for is 24p playback (on pz80 & 85 & 81).
real cinema is more marketing to tie in with the IFC.
urbanshepherd is offline
Old 12-09-2008, 6:45 PM   #3
Thanks: Gave 4, Got 27
Yes 24p real cinema is Panasonic's way to put IFC in 24p feeds, which i think defeats the point of having 24p as it makes it look like video...
24p playback is what everyone else does, simple 24p playback to remove judder on bluray movies.
Capitalization is the difference between "I had to help my uncle Jack off a horse.." and "I had to help my uncle jack off a horse.."
DanDT is offline
Old 12-09-2008, 7:14 PM   #4
MINANTRA's Avatar
Thanks: Gave 32, Got 55
24p playback is also on the PX.
Cheers.
MINANTRA is offline
Old 12-09-2008, 10:14 PM   #5
Thanks: Gave 42, Got 648
From the Panasonic web site..
http://www.panasonic.co.uk/html/en_G...#anker_1404724
rewerb is offline
Old 13-09-2008, 8:01 AM   #6
but is it possible that the 24p real cinema found on the 85 (not the 80) is ONLY activated when you enable IFC ??
This would mean that when IFC is set to off, 24p real cinema is also set to off?
According to the specifics the 85 doesn't have 24p playback, only 24p real cinema. So when its set to OFF you don't have any 24p playback or am i wrong?
85 - ONLY real cinema (activated when enabling IFC?), not 24p playback
80 - ONLY 24p playback , not real cinema
SPiET is offline
Old 13-09-2008, 10:36 AM   #7
All latest Vieras have 24p playback. In addition, the PZ85 (and PZ800/81) have real cinema, which is enabled with IFC on.
rewerb is offline
SPiET (13-09-2008)
Old 13-09-2008, 10:39 AM   #8
Hi Rewerb,
thanks for letting me know.
i read that the advantage of IFC is only with SD content ... sd digital tv, sd dvds etc but not with HD material (ps3, bluray, etc) and not with sports.
Is that correct that its best to turn on IFC only with SD content (no sports)?
SPiET is offline
Old 26-09-2008, 2:22 PM   #9
So is 24p turned on by default? I have the PZ80. Do I need to activate it?
m4morris is offline
Old 26-09-2008, 3:17 PM   #10
No, TV automatically detects whether input is 24p or 50Hz or 60Hz.... and processes accordingly.
rewerb is offline
Old 01-12-2008, 1:25 PM   #11
ro53ben's Avatar
Thanks: Gave 25, Got 68
Hi Rewerb,
I have a PZ85 with IFC.
I use IFC when watching F1, olympic swimming, olympic cycling, playing on my Wii and on other high speed stuff. It works well.
For other "studio" stuff, I ensure it's off as I don't like the effect it creates - truly horrible for movies. But I am grateful to have it on those specific sources.
Due to continued editorial bias by moderators and the inability to have an open discussion, I no longer participate on this site.
ro53ben is offline
Old 01-12-2008, 1:33 PM   #12
Mr Grumpy's Avatar
Thanks: Gave 15, Got 12
Hi Rewerb,
Exactly the opposite in fact.
IFC is meant for HD only and out of sheer curiosity I tested it with SD DVDs and the effect produced was almost as if the tv simply could not cope with having to upscale AND run IFC.
Panny TH50PZ800, Onkyo 876, Arcam DV27a, Sony BDPS350, SkyHD, KEF 5005 (6.1), Xbox 360.
Mr Grumpy is offline
Old 01-12-2008, 1:37 PM   #13
ro53ben's Avatar
I disagree.
IFC can be enabled/disabled on a per input basis. Many of the inputs don't even support an HD source yet IFC is still available as an option. If it wasn't meant to be used, they would remove that option in the settings.
Obviously "24p Real Cinema" only really applies to HD sources, but IFC can be used for any input as desired.
ro53ben is offline
Old 01-12-2008, 1:46 PM   #14
pugheaven's Avatar
Thanks: Gave 25, Got 26
Question Re: Difference between 24p Real Cinema AND 24p playback
Am I being daft here... I have the TH58PZ800, and I have IFC turned off... and have my HD-DVD player set to 1080/24P, so will I be seeing/ running my HD-DVD's at 24fps? i.e. as it should be? I've not had one single camera judder on any panning shots... so I'm assuming I am
Cheers Pug
Panasonic 58" TH58PZ800B Plasma, 100" 16:9 Projector Screen With Optoma HD700x, Yamaha AX630SE, Samsung 1580P BluRay, Panasonic BluRay DMP-BD30, 2xToshiba EP30 HD-DVD, Sky-HD, Samsung 1080P7 DVD, Philips CD-723, Panasonic HDC-SD20 1920x1080 Camcorder
pugheaven is offline
Old 01-12-2008, 1:52 PM   #15
ro53ben's Avatar
You will be seeing the movie exactly as the director intended. If there is any flicker, it's on the 24fps source too.
If you're used to high frame-rate video from games or broadcast TV, then 24fps WILL flicker a little by comparison...you can even see it at the cinema with an experienced eye.
Judder and flicker are entirely different though. A 'normal' UK TV will run at 25fps, the HD movie will be sourced at 24fps. There's a missing frame when showing the 24fps on a 25fps TV and this can cause the judder effect people describe that should not be apparent if you get a 24fps compatible TV.
ro53ben is offline
pugheaven (01-12-2008)
Old 01-12-2008, 1:57 PM   #16
pugheaven's Avatar
Thumbs up Re: Difference between 24p Real Cinema AND 24p playback
Cheers fella, much appreciated, thought that was the case, but then thought, maybe I have to have this option turned on and I missed something . Nice one.
Now to get back to enjoying this TV... and have to say it's fantastic!
Cheers Pug
Old 01-12-2008, 2:06 PM   #17
Thanks: Gave 26, Got 50
Pug - this is fine. If your Blu-Ray is set to output 24p then that is what you'll be watching. IFC is an additional feature and works with or without a 24p source and with either an SD or HD (24p or otherwise) picture.
HeadBanger is offline
Old 01-12-2008, 2:13 PM   #18
ro53ben's Avatar
The easiest way to understand IFC is to think of a stroboscobe (strobe light) in a night club.
When it's flashing at certain rates, people on the dance floor will have the impression of moving around in a jerky fashion. People moving quickly will move a long way between flashes. The faster the flashing, the smoother their movement will be.
An PAL SD TV source is going to have a shutter rate of 25fps which is ok, but not exceptionally smooth when compared to computer games that can run at hundreds of frames per second. To add to this, most screens now run at 100Hz - updated 4 times more often than the source on a PAL signal.
A 100Hz screen is able to be considerably smoother than a PAL source, so what IFC does is attempt to guess how the frame is going to change between the previous frame and the next.
If you watch Lewis Hamilton flying along the straight at 200mph, you may find that his movement isn't entirely smooth as his car travel such a distance between frames it appears to jump from one frame to the next. With IFC enabled, the TV will insert a false image in-between the 2 real ones which clearly makes the movement smoother. As the eye can follow it easier, things like advertising banners etc. are all easier to read....without IFC they can be a bit blurred.
It's not a perfect technology though and on many sources I believe it looks worse. It's just a case of turning it off/on as required.
ro53ben is offline
Old 03-01-2009, 7:04 PM   #19
So, does this mean if your TV is not 24fps compatible but your DVD/BluRay player is, you can watch 24fps on a non 24fps TV just as long as the player is 24fps enabled ?
M.
loser40 is offline
Old 03-01-2009, 10:24 PM   #20
Conspicuous Member
choddo2006's Avatar
Thanks: Gave 362, Got 607
No. It just means that IFC can work on a 50 or 60Hz signal. It'll still have 3:2 pulldown judder of some type even with IFC on, if it's bluray or Region1 DVD.
choddo2006 is offline
Old 30-04-2009, 4:38 PM   #21
Thanks: Gave 5, Got 0
sorry i know this is a slightly old topic but ive re read all the posts numerous times and still cant seem to figure out is there any difference between 24p playback and 24p real cinema?
is there any benefit what so ever to having 24p real cinema?
Tenaciouscdsm is offline
24p, cinema, difference, playback, real
Optimised for Firefox
AVForums.com is owned and operated by M2N Limited
Copyright © 2000-2010 M2N E. & O. E.
