Go Back   AVForums.com > Video Electronics > Televisions > Plasma Televisions
Today's price checkPowered by
Samsung PS-42B430
Panasonic Viera TX-P42G10E
LG 42PQ3000
Panasonic Viera TX-P50X10
Samsung PS-42B430
LG 42PQ3000
Panasonic Viera TX-P42X10E
Panasonic Viera TX-P37X10E
Panasonic Viera TX-P50G10E
Panasonic Viera TX-P42G15E
LG 50PQ6000
LG 50PS3000
 More...Prices updated February 9th at 5:30pm and include delivery.
Old 09-05-2007, 4:56 PM   #1 (permalink)
LG 50PC55 too good to be true??
I would like to upgrade my existing LG 42" plasma to a 50" with 1080p and IDT.
Is the 50PC55 a European set?
I've seen it on several websites and they all list it as a true 1080p panel, ie. 1920 x 1080 pixels.
It can be found for as cheap as £1,400 which seems very cheap!!!
Any info would be much appreciated.
Cheers.
Uber Customs is offline   Reply With Quote
Bretto (09-05-2007)
Old 09-05-2007, 5:26 PM   #2 (permalink)
Thanks: Gave 54, Got 16
Re: LG 50PC55 too good to be true??
Blimey!!!!
I've been waiting for the 50px70 from panasonic to be at JL.....
this link http://www.247electrical.co.uk/epage...PC55?SOURCE=AW
suggests it is true HD (1920 x 1080)
Anyone?
Indeed, it does seem too good to be true!!!
Bretto is offline   Reply With Quote
Old 09-05-2007, 5:47 PM   #3 (permalink)
They also have the 42 inch model listed as 1920*1080
http://www.247electrical.co.uk/epage...?cid=38in_42in
for just £895
UndeadCretin is offline   Reply With Quote
Old 09-05-2007, 5:51 PM   #4 (permalink)
Merefield
Posts: n/a
Originally Posted by Bretto View Post
Blimey!!!!
Anyone?
Probably.
Fuller spec here - even the contrast ratio looks great!:
http://www.rtd.uk.com/product.asp?su...oductid=50PC55
And top it all, claims it accepts a 24p input!?!?!
Old 09-05-2007, 5:55 PM   #5 (permalink)
Thanks: Gave 5, Got 11
Saw this model, mentions LG/Phillips panel, thought it was good price
http://www.directtvs.co.uk/Atec_42_I.../version-1.asp
Sorry just noticed this is the LCD model
neily1970 is offline   Reply With Quote
Old 09-05-2007, 7:00 PM   #6 (permalink)
Originally Posted by Merefield View Post
Probably.
but look at the resolution............
* Resolution: 1366 x 768p
This is too low for full HD, isn't it??
Old 09-05-2007, 7:25 PM   #7 (permalink)
Thanks: Gave 25, Got 81
AJ Electronics show it as having full 1080p resolution...
http://www.ajelectronics.co.uk/ViewP...od_code=50PC55
Just no reviews so far.. Must be brand new.. LG invented plasma right? They should be at the cutting edge really, so maybe are able to release an advanced set for a very low price..
SlingShotUK is offline   Reply With Quote
Old 09-05-2007, 7:29 PM   #8 (permalink)
Merefield
Posts: n/a
Yep, ur right, here's an official looking brochure, albeit in French, but its easy enough to decipher and this confirms its NOT a full HD set
http://www.cobrason.com/data/fr/pdf/50PC55.pdf
And review of 42" here:
http://reviews.cnet.co.uk/television...9290091,00.htm
In other words, move along people, nothing to see here ...
unklewibble (09-05-2007)
Old 10-05-2007, 6:00 PM   #9 (permalink)
...and the plot thickens!!!!
that AJ link certainly claims 1920 resolution........
Old 10-05-2007, 7:43 PM   #10 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 96, Got 1,354
No an American who sold the rights to Matsushita (Panasonic) invented the colour PDP Fujitsu were first to market and no way is the 1902x1080 native res especially the 42"
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 11-05-2007, 3:38 PM   #11 (permalink)
.....and anyone with half a friggin brain (i.e. my girlfriend) would have gone straight to the LG site and found out it certainly ISN'T 1920........
Old 14-05-2007, 11:05 AM   #12 (permalink)
Thanks: Gave 4, Got 1
i was thoroughly impressed with the 50pc55. i have never had a large flat panel before and the colour and picture quality was awesome. it is very light too for such a large panel. since i am novice in my experiences with flat panel displays take my advice with a pinch of salt. nevertheless i think it is excellent. i paid 1100 pounds for it which is not bad. the screen accepts 1080p but turns it into 1080i i think. so it is not native 1080p. search on google/lg website for the 42pc55 instructions to get the full manual. i tested it with my ps3 (games and blu-ray) and also computer and the display was perfect. very bright display with little ghosting/retention on very low power/contrast/brightness setting.
anh_duong is offline   Reply With Quote
Old 14-05-2007, 2:21 PM   #13 (permalink)
stainway's Avatar
Thanks: Gave 20, Got 130
The PC55 models are not full HD but 1366 x 768 (50") and 1024 x 768 (42").
PC 55 replaces the PC1D models. The new models accept 1080p: 24/30/50/60p and also include 100/120 Hz.
However PF95 is the Full HD 1920 x 1080 -now available at 60" later this year also at 50".
You can get the specifications here:
http://uk.lge.com/proddivergent.do?a...ategory_level=
There is interesting review in Swedish here:
http://prylportalen.mkf.se/ArticlePa...MKF857.dbp.asp
They compare the LG PC55 with Panasonic PX70 and conclusion is that both gives great picture-Panasonic is a bit softer and LG a bit sharper.
They also like the user settings possibility on LG-you can set individual colour settings etc... and the Clear filter which reduce the reflections.
They highly recommend the LG PC55 (5 stars).
Samsung LE46A656,Samsung BD-P 1600 ,Samsung AV-R720R,Topfield HSCI 7700 HDTV satellite receiver, Xbox 360, Universal remote control Philips SBC RU 760
stainway is offline   Reply With Quote
Old 16-05-2007, 4:41 PM   #14 (permalink)
Sweeeeeeeeeeet!!
My 50PC55 is being delivered tomorrow.
I'll let you know the spec and write a small review.
Old 05-06-2007, 3:02 PM   #15 (permalink)
Thanks: Gave 1, Got 1
Originally Posted by Uber Customs View Post
Sweeeeeeeeeeet!!
This thread appears to have died a death. How did u find this TV???
RigOMortis is offline   Reply With Quote
50pc55, good, true
Copyright © 2000-2010 M2N E. & O. E.
