If you can't find what you are looking for below, first
do a search , and then post a new thread if necessary.
If you would like to suggest updates to this FAQ section please post here and one of the plsama mods will reply and update below if required.
AVForums Tutorials
A new series of video tutorials have been released explaining everything from 'what makes a great picture' to 'basic TV calibration' and more.
Watch our tutorials at
www.avforums.tv
PURCHASING ADVICE
You need to decide what model to buy and where to buy it from.
The AV Forums can help you with both those decisions.
I have budget £xxxx, what should I buy
One of the most frequent questions asked. Please search for answers and models in your price range before posting if this is the "best". Here's only a few examples. First of, check out the AVForums Special offers
here. Approx £5000
here. Approx £3000
here,
here. Approx £2500-£2000
here,
here. £1500 to spend
here,
here,
here,
here,
here,
here. Approx £1200
here,
here. Under £1000
here,
here,
here.
Where should I buy my plasma from?
We suggest you use one of the many plasma retailers advertising at the AV Forums. Click on one of the advertisements you can see in this forum. The list of advertisers is available
here.
The John Lewis price match FAQ is
here.
Does XYZ support HDMI 1.3?
This
article should help you decide if you really need it
GENERAL PLASMA INFO
HD Ready List of TV's
See
here for a list of HD Ready TV's also.
Information on 1:1 Pixel Mapping
See thread
here for more information
Am I best waiting for the next technology, are plasma's dead or dying?
There is always something better coming along, it's up to you when to jump in and buy one. See some example discussions
here. Also check out the new forum about the "next" technologies
here
What is HD ready?
See
HERE
Lip-Sync Issues between sound and picture on your plasma?
Read it being discussed
here,
here,
here, and
here
Pioneer Plasma's Settings and Information
Is there any info on the new Sky HD service?
See
HERE and the specific Sky forum
here and also HD forum
here
What about John Lewis price match?
See FAQ
here, with detailed threads about price matching
HERE and
HERE
How do I keep my plasma dust free?
see
HERE
How do I check my hours/ get in to the service menu?
DO THIS AT YOUR OWN RISK, SERVICE MENU's ARE HIDDEN FOR A REASON, but if you must, see
HERE
What are recommended viewing distances for plasmas?
In general a 42" be suitable from around 8ft, and 50" from around 12ft but it depends on viewing sources. You can view a HD source from closer than a SD source as there is more detail in the picture - 4.7 feet is recommended for a HD source. Also see
HERE
Which resolutions and refresh rates should I use when using my PC?
If you use the native resolution you will get the sharpest picture, but on the 42" you will get a stretched image on 1024 x 768, you can use the device properties in Media Player to set the ratio at 1.33 (1024 / 768), see extra post below.
I am thinking of wall mounting, any pics and tips?
See
HERE,
HERE,
HERE, and
HERE. Plus general pictures of many, many plasma installs to give you ideas of what's possible
HERE and
HERE, plus specific PV500 pics
HERE, Panasonic Viera's
HERE, and Hitachi 7200
HERE
Is it safe to mount a plasma over the fireplace?
See
HERE and
HERE and
HERE
Can you mount a plasma is a conservatory?
Plasma's aren't great in bright conditions, so unless you have got roof/wall blinds you would probably be better off with a LCD display.
Also see
HERE and
HERE
How do I get my XBox to display hi-def?
Idiots guide
HERE and Softmod kit
HERE
I need more than one component input, what do I use?
You can use an amp to switch inputs or get a dedicated component switcher such as this one:
JS Master Component switcher.
What cables are recommended to use?
For component cables, Mark Grant is recommended. Cable classifieds
HERE. Also TVcables.co.uk have a good selection of QED and other cables.
How much so I budget for cables?
Usually 10% of your kit price
Where to buy your plasma/cables?
Please see the AVForums Links section
here for suggested sites
SCREEN BURN/IMAGE RETENTION/RUNNING IN/CALIBRATION
Does the panel need 'running in' to prevent 'screen burn'?
Across ALL screens it is generally recommended that screens are "looked after" in the first 100-200 hours. Turn down brightness and contrast to approx 50% of maximum settings or less, and take it out of dynamic mode or equivalent. Avoid static images for more 1-2 hours where possible during the running in period.
What is screen burn/image retention and can it be avoided.
This has been discussed
many, many, many times. Please use the Search This Forum function for your model prior to posting a new thread about it. Here are just a few selections:
Rumour or Reality, Poll on it
here, Pioneer 436, see the Pioneer FAQ thread
here, Panasonic
here and
here, and
here. And if you are really worried about screen burn, take a deep breath, and look at
this, and
smile
What are the best settings to use after this run in?
The cheapest way to set up the panel is using a DVE disc or for the ultimate calibration you need to get it ISF'd when you have got all your kit set up.
How do you use the DVE disc?
See the projector sticky
HERE
Where can I get the DVE disc from?
A few DVD online retailers sell the DVE discs, including
Play and
AxelMusic
What is ISF calibration?
see
HERE and
HERE and
HERE. See discussion of ISF
here and
here. Example of PV500 ISF results see
HERE
I haven't got a DVE disc yet, what settings are people using?
See thread
HERE
WARRANTY/AFTER CARE
Can I get an extended warranty from somewhere else?
Yes, Av-Sales allow you to purchase one up to 6 months after buying it. See also warranty discussions
here,
here,
here,
here,
here,
here,
here,
here,
here
Cleaning your plasma
See thread
here for cleaning cloths for plasma's
Thanks to Mal/Stuart/Hornydragon for the original FAQ sections that I have updated and merged together
