| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
LinkBack | Thread Tools | Display Modes |
#2 (permalink) |
I've been told it is
The delaer I bought my PW5 off told me that that there was no difference between the Unicol tilting bracket between the Pannys series 5 and series 6.
__________________I'm gonna stick with the 5 as I'm completely satisfied with its performance. If in doubt, try dropping a mail to Panasonic/Unicol. Rick TH-42PWD5 Plasma, Sony STR-DE695+Pioneer VSX-2011S, Gallo 5.1, Pioneer 444S, Pioneer On Digital Freeview Box |
#3 (permalink) |
Assured Advertiser
napp
__________________If your buying second hand be wary of how old the Unicol mount is. If it was initially purchased during the last twelve months then your probably going to be safe to use it with a PWD6. If it was purchased before then you have to confirm if it has the correct type of 'indents' to work with the back panel of your display - Panasonic changed the back panel on the 42" chassis during the life of the Series 4 models (about 18 months back) so Unicol had to follow suit. I'd double check with Unicol and get an original invoice or order date to give them some idea of when any second hand brackets were manufactured and to what pattern. Best regards Joe The Media Factory - Install, Connect and Control. |
#4 (permalink) | |
napp |
| Bookmarks |
| Tags |
| panasonic, wallbracket |
| Thread Tools | |
| Display Modes | |
Global Gold Web Hosting |
