AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 28-08-2003, 5:18 PM   #1 (permalink)
ensyed
Posts: n/a
panny pwd5 vs. fujitsu VCA21EH/VHA20ES plus mounts etc
I am in the market for a 42 inch plasma and 3 TVs seem to fit my budget. I am new to the plasma market but have owned an HDTV in the US.
1) I need help choosing between the panny and fujitsu. Also what is the difference between the 2 fujitsus?
2) Also what kind of wall mount do you recommend? I will be hanging it over the fireplace (plaster (15 millimeters and brick under the plaster) Will need to drill 50milimeters.
3) I will be using this with Sky + and a DVD player. Do I need to buy any kind of converters to connect? I have read posts about VGA to ... etc. But dont know anything about these inputs. I understand what are composite, S-video and component inputs as I used them in the US.
Rummy
Old 29-08-2003, 6:30 AM   #2 (permalink)
MAW
MAW's Avatar
Thanks: Gave 26, Got 494
I should think the PW5 and VHA 20 are the bargain plasmas of the moment. Isn't the VCA21 a commercial model? Not certain as Fuji have many and confusing model no's. They all have the very same glass, Fuji have a video board that works though... none of that s-video and composite problem. IMHO the fuji buzzes louder, though it's not serious. Check when you buy about the VCA, cos many commercial fujis do not accept YUV, only RGBHV from those BNC's. You could use a cable like the one in a nearby thread with the Fuji, but you might have a problem with Macrovision trying to pass the DVD signal thro' a recording device, I've never tried with Sky+. Failing that, you could try s-video for sky, your box may well have a socket, and component for a decent DVD player. S-vid often works well for sky, and if not then RGB to VGA is the usual preferred route.
In short, toss a coin between the Pnny and the VHA 20, be careful of the VCA21 till you have asked the YUV question of the dealer!
MAW is offline
Old 29-08-2003, 1:57 PM   #3 (permalink)
ensyed
Posts: n/a
Thanks. I will stay away from the commercial model.
I was also told that while the Panny does better blacks, the Fuji shows sharper images. Is that correct?
Has anyone purchased from nexnix.com
They appear to have the best prices on these TVs.
Old 29-08-2003, 5:09 PM   #4 (permalink)
MAW
MAW's Avatar
Rowlocks to the stories you've been told, it is actually the same glass, the blacks will be the same, I've never noticed any difference in sharpness, the main difference is the name on the badge and the Fuji's better video board. I believe Nexnix are reputable, I should think their panny 5 will be a euro import. If they tell you otherwise, ask to see the box. A euro screen says 'TH42PW5-EX' a uk one TH42PW5-BX They are identical, but the euro screen will not have the (useless clause) swap out warranty. A good dealer will do that for you though, ask them if they will. If you catch anyone lying about euro imports, and many try it, draw your own conclusions.
MAW is offline
Old 29-08-2003, 10:04 PM   #5 (permalink)
As has been posted the Fuji uses the same glass as the Panny 5. However, Fujitsu have added their AVM (Advanced Video Movement) processing. Having not seen it, I dont know how it affects picture, however I have hear people state negative opinions upon it
Have a look at the extract below, from a review of a Fujitsu panel with AVM:-
As you’ll have guessed, AVM Plus claims to improve plasma’s ability to cope with fast- moving source material.The way it does this is by attempting to turn non-progressive, interlaced material (such as a Freeview channel) into progressively scanned material. Fujitsu describes the feature as 'on-site progressive’. And, true to the company’s boast, it does dramatically reduce 'jaggies’ – those nasty psychedelic edges you can see around a weather presenter – and the result is a smoother, softer image.The problem is, there’s also a massive increase in general noise and fuzz that becomes impossible to ignore, especially on low-detail scenes. Unfortunately, you’ll give up on AVM Plus because it’s one step forward swiftly followed by one step back
Best to check Id imagine.
Tony
tbrar is offline
Old 29-08-2003, 10:35 PM   #6 (permalink)
I would say you need to go and look at the screen before you order. The Panny 5 is renowned for its flicker effect - havent looked at the fuji's so cant comment but if its the same glass im assuming so. Some people love it - others hate it !!
Definately look before you buy !!
RickB
Hitachi 42PD3000 now showing in a living room near me !!! Sony STRDB940 AV amp used as a processor driving Linn amps/speakers until I can afford a better AV processor !!
RickB is offline
Old 29-08-2003, 11:06 PM   #7 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,104
VCA is commercial and VHA is ok HHA is Hi def panel and much better Panny PW6 is cheaper and better specced than PW5 also new PA20 has integral tuner not set the Pa20 up yet but the HHA compares verywelll to the PW5 PW6 an overall better screen almost as good as the PW4!!!
hornydragon is offline
Old 23-02-2004, 9:25 PM   #8 (permalink)
Davidgilmour's Avatar
Thanks: Gave 31, Got 17
Tony
that quote was from T3 magazine....... (!!!!! )http://www.plasmacity.com/PLASMA_DIS...JITSU/4242.htm
Davidgilmour is offline
fujitsu, mounts, panny, pwd5, vca21eh or vha20es
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
