AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 22-01-2003, 12:24 AM   #1 (permalink)
satch
Posts: n/a
unicol wall mounts
has anyone got one of these for there there panny?
just wondered how slimline they are compared to the pan one?
as i cant get hold of the pan one at a good price at the moment OUT OF STOCK.i wont mention the two companys that took my order for one and said they were in stock then nothing turned up!!!
so my new panny is still in its box while i wait for one.
i now have the luxury of watching the kids 14" tv!!!through binoculors?
Old 22-01-2003, 3:08 AM   #2 (permalink)
I have one on my panny very slim just like the panny one got my from here they are very good ..
Boogie man
Denon AVC A1SE, Rotel RB 1070,B&W CDM7SE , B&W CDM CNT, Meridian 506, Sony DVPS7700,42" Panny S5, Sky+, ]
boogie man is offline
Old 22-01-2003, 3:57 AM   #3 (permalink)
Phatboy's Avatar
Thanks: Gave 1, Got 0
Me too, ivojo supplied unicol mount non tilting. Its approx 15mm deep. I used eight large coach bolts to fix it to my chimney brest!
Mark
Give me a Snowboard & Fresh Untracked Powder !
Phatboy is offline
Old 22-01-2003, 4:08 AM   #4 (permalink)
StooMonster's Avatar
Thanks: Gave 122, Got 264
Unicol PLX Flat Wall Bracket
I got one from Ivojo too, and it works very well: easy to fit, and slimline.
Attached to my chimney breast via eight studs in cement resin, my Panny5 50" is not going to fall down.
StooMonster
StooMonster is offline
Old 22-01-2003, 2:32 PM   #5 (permalink)
Another happy Ivojo customer here . . . received my Unicol bracket from them yesterday, looks very slimline . . . now all I need is my new Plasma to mount on it !!
Panny TH-50PF10, Antec Fusion HTPC, Sony BDP-S350 Blu-ray, Xbox 360, Wii, Sony STR-2400ES AV Receiver, Tannoy MX + Paradigm PDR10 (5.1), Virgin Media V+, Harmony 585
MontyUK is offline
Old 22-01-2003, 2:39 PM   #6 (permalink)
Are they listed / detailed on their website. I can't seem to find them
House is offline
Old 22-01-2003, 3:12 PM   #7 (permalink)
I got mine directly from Unicol - took about 2-3 days (I said it wasn't urgent!) and was cheaper than a retailer
nickt is offline
Old 22-01-2003, 5:30 PM   #8 (permalink)
Click on a plasma, and it's listed in the "extras" at the bottom of the page.
StooMonster
Old 22-01-2003, 6:06 PM   #9 (permalink)
jont's Avatar
Location: Now hanginaround Aylesbury instead of hanginaround Glasgow
Thanks: Gave 32, Got 204
Unicol and ivojo are same price according to websites ??
flat wall mount for mine ... £129+VAT
rgds
Jon
my toys ... Arcam FMJ AV8, P7, DV27A+sdi | B&W 805s & HTM2 | Anthony Gallo Micros & sub | Sanyo Z4 | Samsung LE37R8 | SkyHD | Toshiba HD-E1 | Sony BDP300 | xBox360 Elite | Wii | AppleTV | iMac 3Ghz, MacBookAir (ssd) & MacMini | Nikon D300 & 17-55mm f2.8 | 3G iPhone
jont is offline
Old 23-01-2003, 1:25 AM   #10 (permalink)
satch
Posts: n/a
is it the plx one that im looking for guys?
Old 23-01-2003, 4:25 PM   #11 (permalink)
Assured Advertiser
Liam @ Prog AV's Avatar
Thanks: Gave 3, Got 538
Satch,
The PLX is the 15-20mm standard wall mount, the PLW adds tilting ability but with that comes an extra 20-30mm!!
The PTX is guranteed to be 20mm or under *and* tilt but it's about £100 more than the standard mount.
HTH
call me: 01892 860801 / e-mail me: liam@progressive-av.com
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Ex-Demo Arcam fmj AV9, P7, DV139 - £3,350!!!
Liam @ Prog AV is offline
Old 27-01-2003, 9:10 PM   #12 (permalink)
Hi All -
I have just been to the Unicol factory in Oxford, and they demo'd the fixed and tilting wall brackets for me. (I wanted tilting, they said it wasn't necessary for home use, they showed me the differences).
Got a fixed bracket for £129 + VAT. Very helpful & said I could swap it for a tilter if I needed to. Fixed bracket is v. slim indeed.
Excellent customer service - if you're in/around Oxford, go get one direct.
I know I could have mail ordered one, but there's nothing like taking something home...
gileso is offline
mounts, unicol, wall
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
