| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Quick Toshiba 42 Inch Wall Bracket question ..
Eventually ordered the Toshiba 42WP16E (Richer Sounds Offer) and I am wanting to order the wall bracket (non-tilt).
I have read numerous times that this screen is a Panasonic 'clone' but would I be right in saying that the Panasonic wall bracket would be suitable ?? Also if anyone has found this bracket fairly cheap and available now I would appreciate your responses ... |
#2 (permalink) |
The cheapest I could get the Panny bracket (TY-WK42PV1) for was £217.00 plus £10.00 postage from Empire Direct.
Most shops were wanting £350.00 for it. Does it not say in the operating instructions about which bracket to use. Regards Toonarmy |
#4 (permalink) |
Yes, the panny bracket is fine with the toshiba plasma (this is what I have).
The panny bracket is a bit overpriced, I looked at the unicol one but it was a bit deeper than the panny so the plasma would be away from the wall by a bit more - in the end I just went for the offical panny bracket. |
| Bookmarks |
| Tags |
| bracket, inch, question, quick, toshiba, wall |
| Thread Tools | |
| Display Modes | |
Global Gold Web Hosting |
