| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Rule of thumb for mounting height?
Hi to all,
just wondering about what different heights people have mounted there plasmas at on the wall, is there a perfect height/formula or a rule of thumb people follow or just whatever suits. im mounting my pd7200 on sat and thinking about mounting it so the centre of the plasma is level with my eyeline, is this what others have done or should i base it on something else for the perfect height?? many thanks andy |
#2 (permalink) |
Scientifically the height most easy on the eyes is at or below eye level.
Basically to look up the eye muscles have to be contracted, while to look down the muscles are relaxed. This is supposidly how hypnotism works as they always hold the dangly swingy thing above your eye level meaning your eyes have to work hard to track it. Hence "your eyes are getting sleepy" type gubbins ![]() |
#3 (permalink) |
I made a cardboard cutout of the screen size and taped it to the wall so try out different heights. In the end, I mounted it so that the horizontal centre was at my eye level when seated. It looks like the natural height
__________________436XDE |
#4 (permalink) |
I used a similer method to yellowpostit - although I did not have to get the scissors and cardbopard out, luckily we had a door mat that was exactly the same size as my screen
so I experimented sticking the door mat to the wall with carpet tape in various positions . The misses thought I had gone totaly mad but it does work . I was going to put the screen in the centre of the wall but thanks to the door mat I found that it was best for me 3-4 inches above the centre line.I think a lot depends on how tall you are and how high the chair is you are sitting on and how close your eyes are together etc etc......so you are just going to have to get the cardboard and scissors out, unless you have a door mat like mine (door mat came from poundland by the way) ![]() |
#5 (permalink) |
Andy what type of Scientis are you? Muscles work in pairs, and there will muscels that contract to look down. for example - To make you arm straighten at the elbow, your tricepts need to contract - it is not you bicept relaxing that does the starighting.
Tis all true - but I hope you are reading this with humor present! Anyhows - I am set to do the same with my new screen - and I am going to place at eye level from the most common viewing position. At the cinema you tend to sit at the mid level upwards - the screen is then at eye level, or slightly down (Which i agree is a far more relaxed position). You don't want to be looking up as this will in more ways than one become a pain in the neck! |
#6 (permalink) | |
Assured Advertiser
Anyway, I work to around one metre to the middle of the screen ideally. But usually end up having to push them up a bit to accomodate aesthetic requirements. Mine is about 80cm to the middle and is perfect for my low slung sofa ![]() call me: 01892 860801 / e-mail me: liam@progressive-av.com Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers. Ex-Demo JVC, Sim2, Arcam |
#7 (permalink) |
Good point Liam about the downward movement of the eyes needing less effort thant the upward one, using this same logic should we not also consider the hoizonal positon of the screen in order to reduce the strain on the legs during the walk to the bear fridge when the adverts are on
What is best - closer to the kitchen for the fridge or closer to the loo for when relief is required ![]() |
#8 (permalink) |
Assured Advertiser
Ahh didn't take that into account. In my lounge the beer fridge is within arms reach of my sofa.....
__________________No in-cinema toilet yet though!!!!! call me: 01892 860801 / e-mail me: liam@progressive-av.com Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers. Ex-Demo JVC, Sim2, Arcam |
#9 (permalink) |
I will be liberating the beer fridge from the kitchen over the weekend operation codename: 'carling crusade'
Still have no solution for the in cinema toilet though - perhaps we should start a new thread - "How to I wall mount a toliet to a dot & dab plasterboard" ![]() |
#10 (permalink) |
Assured Advertiser
PMSL!!!!! I'm quite worried about myself - just after posting I sat back for five minutes and did seriuosly contemplate the logisitics of it! Anyone see that episode of Men Behaving Badly lol
__________________call me: 01892 860801 / e-mail me: liam@progressive-av.com Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers. Ex-Demo JVC, Sim2, Arcam |
#11 (permalink) |
Thanks: Gave 68, Got 109
Do a Catch 22 white man,switch the catheter bag to the drip and vice versa.Easy!No different from London tap-water!
__________________Anyway,back on thread,I read somewhere,probably on here,that the ideal height was to have the screen so that 2/3 was above your eyeline and 1/3 below.I did the large piece of cardboard (more entertaining than many tv shows) thing and by sheer coincidence i found that the most comfortable height was within an inch of aforesaid height. Now,where's my beer........... I would be unstoppable,if only I could get started. Pioneer 435XDE/PDP-26,Denon 2910/2805,Digifusion FVRT200,Monitor Audio S6/S2/SLCR,REL stampede,Wireworld/Van Den Hul/QED cabling,Italian Spinone dog hair |
#13 (permalink) |
Damn,
So I need a working triangle between my screen, fridge and loo. I thought that was just in the kitchen. This home Cinema lark is more complicated than I thought We put our Plasma above a false fire mantle shelf and have no problems with it at that height (out of the range of sticky fingers) dave |
#14 (permalink) |
Another thing to consider is that if you are reclining then you can still be looking down even if the screen is above eye level.
__________________Hitachi 42PD7200, Topfield TF5800PVR, Marantz SR7500, DV6600, Harmony 885, Mac Mini HTPC
B&W602S3, LCR600S3, 600S3, Rocket UFW-10, XBOX 360 |
#15 (permalink) |
Smething someone suggested previously on avforums worked a treat for me (as well as sticking up cardboard)...sit on you sofa and close you eyes, move you head around a bit with you eyes closed and carefully position you head (with eyes still closed) until it is in the most comfortable position and then open you eyes and hey presto thats the optimum watch height !
I tried the above and it suggested mid-screen should be about a meter of the floor - I then traded comfort off slightly for looks and made the bottom of my plasma 1 meter of the floor.... Very comfortable to watch and looks great on the wall ! |
| Bookmarks |
| Tags |
| height, mounting, rule, thumb |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Plasma Size Rule Of Thumb? | maffup | Plasma Televisions | 15 | 17-02-2005 8:09 PM |
| Height from ceiling calculation… arrrggghhhh!!! | t1grm | DLP, LCD and D-ILA Projectors | 11 | 27-12-2004 8:22 PM |
| rule of thumb | oscarmadfish | Plasma Televisions | 0 | 03-11-2004 11:06 AM |
| Decoding a Height Channel | Stuart M. Robinson | Integrated AV Amplifiers and Receivers | 0 | 02-03-2003 12:29 AM |
| Rule of thumb for Budget? | moshea | Speakers | 3 | 31-10-2002 11:45 PM |
Global Gold Web Hosting |
