AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 20-11-2005, 8:11 PM   #1 (permalink)
kdk
Posts: n/a
How to Mount Plasma on Plaster Wall?
I want to mount my Philips 37" LCD TV onto one of my walls which is made up of 100% plaster, there is no studs or anything and is about 3" thick. The TV weights about 35Kg's, do you think it would be safe to mount my TV onto the wall as it is? What would be the best way to mount it and which bolts should I use and where I can get them from? Any advice would be much appreciated.
Old 20-11-2005, 10:17 PM   #2 (permalink)
johnscarlet's Avatar
Thanks: Gave 87, Got 303
No More Nails
Whats the plaster stuck to ?
John
My opinions expressed here do not represent those of the AV Forums or it's associated websites
The posting of vast slabs of text from news sites and other freely available sources is not acceptable,especially when copyright may be an issue, please provide a link.
johnscarlet is offline
Old 20-11-2005, 10:52 PM   #3 (permalink)
av2diefor
Posts: n/a
Sounds like its paramount partition.
Its plasterboard with egg box carton in between.
Not good for fixing too i'm afraid, 35kgs is a lot to bear, it can be done if you know how.
Not for the diy route unless you are familiar with it.
Old 20-11-2005, 10:57 PM   #4 (permalink)
Thanks: Gave 36, Got 41
Surprised to hear this TV weighs 35KGs? 35LBs maybe, but not KGs!
Dave.
dodgyd is offline
Old 20-11-2005, 11:15 PM   #5 (permalink)
This is a tricky one, if you can i would try fix through the wall with M8 threaded rod into a horizontal batons, top and bottom. One the other side you could try and disguise this by mounting a shelf or something over the top of it, if not i would consider making a wooden frame attached to the plaster board with heavy duty plaster board plugs. This is a risky situation, but if you distribute the weight across a large area then it should be strong enough. If your not brave enough for that then its either a ceiling mount with a pole and bracket or you could build a false wall with proper stud partitions. Either way i would be worth cutting a chunk out of the wall to see whats supporting it at the mo.
Good luck
Please note this advice is free and given when i am very tired, so if you tv falls on the floor and smashes into millions of pieces then its nowt to do with me!!!!
alliwant is offline
Old 20-11-2005, 11:35 PM   #6 (permalink)
av2diefor
Posts: n/a
The very reason my lips are sealed
mount, plasma, plaster, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Running speaker cable behind plaster board/stud wall? craynerd Home Cinema DIY 14 16-12-2005 5:29 PM
Plasma Wall Mount - Tilt or No-Tilt? MillionDollar Plasma Brackets and Mounts 0 20-11-2004 11:18 AM
Universal wall mount for Sony plasma? Miles@9 Plasma Brackets and Mounts 4 04-05-2004 6:49 PM
Plasma wall mount brackets bokkie Plasma Brackets and Mounts 1 06-03-2004 7:54 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
