AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 17-11-2005, 10:51 AM   #1 (permalink)
Thanks: Gave 3, Got 0
Question Mounting a plasma IN a stud wall
I'm having a new stud wall built from scratch (dividing 2 rooms), and I plan to mount a 506XDE in it, with the main body of the screen in the wall and just the 'frame border' sticking out from the wall.
Has anyone done this and got any advice, pics of the stud build etc?
I plan to ventilate it through vents on other side of the stud wall.
Many thanks!
damolong is offline
Old 17-11-2005, 11:48 AM   #2 (permalink)
Try doing a search for Xstyle (member on this forum) who has an excellent photographic review of mounting a plasma in a stud wall. Find his profile account then there is a link on his sig. Well worth a look as it sounds very similar to what you're attempting.
Best of luck.
acrmorris is offline
Old 17-11-2005, 2:46 PM   #3 (permalink)
Best of luck.
Just what I was looking for. Many thanks.
damolong is offline
Old 17-11-2005, 3:45 PM   #4 (permalink)
Keep us updated on your progress.
mounting, plasma, stud, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
plasma + xbox + wall mounting = wiring advice needed gdi Plasma Brackets and Mounts 1 12-09-2005 4:47 PM
General Newbie Help Required About Wall Mounting Concerns / Ideas and HD advice about87 Home Cinema DIY 6 19-08-2005 11:11 PM
Wall mounting a plasma with backing board holo Custom Installers and Installations 2 02-08-2005 10:28 PM
Recess in plasterboard wall for a 42" plasma. Advice...? robyoung Plasma Televisions 10 19-05-2005 8:59 AM
mounting panny plasma on brick wall iandavidcassidy Plasma Brackets and Mounts 1 27-06-2004 8:06 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
