AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 17-11-2005, 9:25 AM   #1 (permalink)
milkmanchris's Avatar
Thanks: Gave 29, Got 55
baby Worries - Pedestal Or Wall Mount Mounted?
Sorry if this has been askied a thousand times.
My TH42PE50 lives on the cabinet that came with it in the corner of the room (not pretty), anyway yesterday in an expensive visit to buy some of the ikea leds from another thread (fantastic by the way), I ordered a very nice leather corner sofa thats going to replace the aged hand me down suite we have at the moment.
I am going to move the TV and kit to a new wall, however been a new house with crap walls, and my total ineptitude with DIY I was thinking of options. I saw a very nice Benno cabinet in ikea yesterday with a plasma and pedestal combo sat on top of it, its rated at 100kg max load so this should present no probs for my kit, and the height would be about the same as me wall mounting the plasma.
My dilema is my 7 month old who is into everything at the moment, and the worry of her been able to pull the plasma over if it was pedestal mounted (i know the combine weight would be in excess of 50kg) but the worry is still there.
Has anyone got this setup and the youngsters too, or is it a case of if she is growing up with it there it should never bother her.
Thanks for your input, maybe i should post this on a baby forum too
milkmanchris is offline
Old 17-11-2005, 9:55 AM   #2 (permalink)
Daddy k's Avatar
Thanks: Gave 312, Got 250
well i have an 8 month old too and luckily mine is on the wall, sort of!
!click the link on my sig!
what i have done is place the panel on the fireplace surround! then just used some small brackets that came with the panel to prevent tipping. 2 go onto panel, 2 into wall,and bolted them into the wall with metal expanding wall plugs from b&q,l ine em up and bolted em together.
its very safe! been up for about 7 months iv tried pulling it etc no movement, so if u have a fireplace it may work for u, very simple! safe! cheap!
if this aint an option or something you dont like a bit of advice!
my girlfriends little bro (3 years old) is always running to the tv, bouncing off it and running back, luckilly its a beast of a crt, so it dont budge, but just think of the dissaster if it were a plasma!!!!!
Harman Kardon AVR230 Amp. BK Monolith DF subwoofer. B&W VM1 speakers x5.
Samsung Q96 50" HD plasma running Sky HD @ 1080i
Harman Kardon DVD 22. Sky+ Multiroom. XBox 360 add me on LIVE:krismc1.
See my setup in members gallery:"dads new pad"
Daddy k is offline
Old 17-11-2005, 10:32 AM   #3 (permalink)
the highlander's Avatar
Thanks: Gave 1, Got 2
he looks like the kind of person who would gladly smear your nice plasma with jam and any other substances he could get his hands on
i have my 42pe50 on the wall mate and my house is only 4 years old .
as long as you use the proper bolts you will not have a problem getting it on the wall
My flickr 400D|BG-E3|50mm f1.8|Sigma 18-200 OS|Tamron AF 11-18|Tokina 28-70 f2.8|Tokina 80-200 f2.8|Canon 20-35(new) for sale|
the highlander is offline
Old 17-11-2005, 11:09 AM   #4 (permalink)
Daddy k's Avatar
yep you can see the look on his eyes already! and listen to the thoughts going thru his head "wooow daddy has got a big etcha sketch! i best get drawing for him"
Daddy k is offline
Old 17-11-2005, 11:33 AM   #5 (permalink)
Thanks for the advice guys, not sure how Baby Leah will take to the gender reversal thing though
Old 17-11-2005, 11:36 AM   #6 (permalink)
Daddy k's Avatar
damn that always happens lol.
its worse when a foreighner asks what is it boy or girl, and he/shes covered head to toe in pink or blue!
apparently its a british thing!
Daddy k is offline
Old 17-11-2005, 11:37 AM   #7 (permalink)
Daddy k's Avatar
help we have an terrible illness!
whats it called???
mad cow dece......
oh no sorry its erm FOOT IN MOUTH
Daddy k is offline
Old 17-11-2005, 11:40 AM   #8 (permalink)
sorry mate didn't notice but she has made your mind up on getting it on the wall girls are worse than boys at that age
Old 17-11-2005, 1:08 PM   #9 (permalink)
Thanks: Gave 74, Got 68
It's very cruel to stick babies on walls
Kevo is offline
Old 17-11-2005, 1:47 PM   #10 (permalink)
Drd
Drd's Avatar
Thanks: Gave 68, Got 109
Personally,having had 3 of the little blighters,I'd stick mine on the ceiling.
I would be unstoppable,if only I could get started.
Pioneer 435XDE/PDP-26,Denon 2910/2805,Digifusion FVRT200,Monitor Audio S6/S2/SLCR,REL stampede,Wireworld/Van Den Hul/QED cabling,Italian Spinone dog hair
Drd is offline
Old 17-11-2005, 2:24 PM   #11 (permalink)
Thanks: Gave 85, Got 5
I had the same dillema when I bought my plasma a few months ago. Went with a Pedestal and bought a nice glass unit to put the plasma and ped on.
Then when my son started crawling, two months ago, I went to B&Q, bought a sheet of clear perspex, and a few lengths of 1 inch pine. Made a frame out of the pine and cut the perspex sheet to fit. Positioned it in front of the TV and it works a treat.
Before I built it, my son was drawn to the TV and I was constantly cleaning the glass top and screen. Dont know if everyone is the same as me but the plasma screen HAS to be clean and not have any fingerprints on it. (Just call me anal).
Some people may think it was a bit extreme but the barrier does the job, looks nice and I can still work the sky + and dvd recorder as the infra red works through the perspex sheet.
dodgydaz is offline
Old 17-11-2005, 6:13 PM   #12 (permalink)
Chris Blackwell
Posts: n/a
We've just had cabinets with solid wooden doors made for exactly this reason. Jake is now walking and into everything but now all the black boxes with the fun slots and switches are closed away I can breathe easy again. I've bunged a Xantech IR system in as well to control everything from a Pronto without opening the doors (works a treat!) The 506XDE screen is pedestal mounted and sits on top of the cabinet. Frankly it's so heavy I doubt he could pull it over, and anyway he's only allowed in the TV room when we are in there to keep an eye on him.
Here's trouble, complete with bandaged scar!
baby, mount, mounted, pedestal, wall, worries
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wall Mount Cables ecnirp Plasma Brackets and Mounts 8 24-10-2004 7:55 PM
Anyone wall mounted their 434/504 Pioneer? dealmaker Plasma Brackets and Mounts 37 19-03-2004 6:50 PM
Advice needed on Wall Mounting a Panny Plasma the thing wnn Plasma Brackets and Mounts 7 22-01-2003 4:08 PM
Fitting a Panny Th42pwD4 Unicol Wall Mount bluebear Plasma Brackets and Mounts 6 05-11-2002 8:20 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
