| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Plasma corner mount if poss?
Hi my friend after a plasma 42" tv or maybe a 32" lcd tv thing is he is wanting to mount it in a corner of his room it is near enough a right angle only thing i though for him to do is knock a wooden frame up of some sort then mount a plasma/lcd back plate onto it.Is there any corner type systems about at all or any other suggestions thanks
#4 (permalink) |
Can you not use a corner unit?
__________________If not I would make some sort of wooden frame that you can screw you plasma bracket to, it may be worth getting a good joiner in. AV: Panasonic TH-42PV500 Digital SLR: Canon 350D with Sigma 10-20mm, Canon 24-105 f4 L IS, Canon 50mm f1.8, Speedlite 430EX and handgrip, Crumpler Geekstar MY PICS---FLICKR Consoles: XBox 360, Wii, PS3, Gamecube, N64, Black NDS lite, R4DS |
| Bookmarks |
| Tags |
| corner, mount, plasma, poss |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| HELP - Slim Wall Mount Plasma Speakers ? ? ? | cl0nd0n | Speakers | 8 | 25-10-2005 5:24 PM |
| how high to mount a plasma screen | john.-h123 | Plasma Brackets and Mounts | 8 | 02-10-2005 6:20 PM |
| Plasma mount on timber board? | lisag | Plasma Brackets and Mounts | 10 | 07-01-2005 8:21 AM |
Global Gold Web Hosting |
