AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 11-11-2005, 11:11 AM   #1 (permalink)
Azzin's Avatar
Thanks: Gave 1,350, Got 261
Question To wall mount yet or not?
Hi all,
So here's the thing....
I currently have my new Hitachi 7200 sitting nicely on it's stand on a large Ikea cabinet in my living room.
I want to mount it on the wall behind the cabinet at roughly the same height as it is now.
I currently have Sky +, a 5.1 amp, my DVD player, & my wireless music streamer situated on the shelves in the cabinet.
I was planning to mount the TV tomorrow,get rid of the Ikea cabinet & get myself some kind of upright set of glass shelves type unit to sit directly under the TV housing the SKY + etc.
I'm planning on running all the leads out of the TV behind the wall & come out of a nice neat (hopefully!) hole in the corner by the skirting.
However.....I take delivery of my XBOX 360 in 3 weeks time, & was wondering if it would be better to delay the mounting of the TV tommorrow until I have the 360?
If I do mount it tomorrow (n00b alert here!), what would be involved in removing it again in 3 weeks time to 'plumb in' the 360 component leads?
I hope that makes sense, I'm really keen to get it mounted, but just want to know if it's better to mount tomorrow & remove in 3 weeks time (thus getting the bulk of the work out of the way tomorrow), or wait & do the whole thing once the 360 has arrived?
All input/advice welcomed.
[Edit]-Here's a pic of the Ikea cabinet.
The other reason that I'd like to get rid of it is that it really is too big for my needs & far too deep than is necessary (hence my desire for a glass shelved unit.
If anyone has any recommendations for glass shelving units, I'd be grateful to hear them too.
Here's the kind of thing I had in mine (courtesy of Richer Sounds)
Thanks again.
Azzin is offline
Old 11-11-2005, 11:20 AM   #2 (permalink)
Thanks: Gave 1, Got 9
cant you just plumb in the 360 lead now ?. Run the cables you intend to use for connecting it up so its all ready to go when your xbox arrives ?
Surely your cable run will require longer leads than they ship in the box anyway
indolent is offline
Old 11-11-2005, 11:24 AM   #3 (permalink)
Azzin's Avatar
The cable's not available to buy yet.
The machine is launched on 02/12/05, although there are rumours that all accessories & games will be available to buy the week before (25th Nov), but that's nothing more than a rumour currently.
Azzin is offline
Old 11-11-2005, 11:25 AM   #4 (permalink)
I would suggest there is nothing stopping you from mounting now, as long as there is enough space in the conduit to run extra cables through. I did a similar thing and routed a few lengths of thin nylon string through the conduit so I could pull any extra cables through as and when required. Still have two bits of string left for any future updates (Roll on SKY HD)
acrmorris is offline
Old 11-11-2005, 11:48 AM   #5 (permalink)
Azzin's Avatar
The thing is, I was planning on just drilling a hole directly behind the TV for all the wiring/leads, so if I do this tomorrow I'll presumably have to remove the TV once the XBOX arrives in 3 weeks time?
Cheers for your input.
Azzin is offline
Old 11-11-2005, 12:02 PM   #6 (permalink)
Depends on the wall mount and location of the sockets. I have the pv500 which is an absolute to put cables into when it's hanging, but it is still possible. If the worst comes to the worst, unhooking from the wall mount shouldn't be too big a deal.
Also, if previous games console releases are anything to go by (PSP anybody!) I wouldn't hold your breath for the XBOX release date. Just make sure you plan wisely and you shouldn't have a problem when the correct cables are available.
Old 11-11-2005, 12:25 PM   #7 (permalink)
Azzin's Avatar
Depends on the wall mount and location of the sockets. I have the pv500 which is an absolute ******* to put cables into when it's hanging, but it is still possible. If the worst comes to the worst, unhooking from the wall mount shouldn't be too big a deal.
I've got a Hitachi 42PD7200 & I've ordered one of these: http://www.av-sales.co.uk/proddetail...B05-NT&cat=190
So I guess I need to know how easy it is to remove the TV once it's mounted, so that I can then poke the XBOX component cables through the hole in the wall?
It's definately coming out on Dec 2nd-I've even had it confirmed to me that I will be guaranteed on on launch day!
Azzin is offline
Old 11-11-2005, 12:40 PM   #8 (permalink)
Thanks: Gave 11, Got 11
You could always stick a component lead in and then get something like http://www.js-technology.com/product...959fdd7543443a and then you can always add another component source in if required.
Panasonic 50PX600, Panasonic DMP-BD55K, Toshiba HD-A30, Denon 2900, Onkyo 876, Cabasse Xi, PS3, Wii, Nikon D80
Parklife is offline
Old 11-11-2005, 12:46 PM   #9 (permalink)
Thanks: Gave 300, Got 163
Just a note on that glass rack - it will only take a 7kg weight per shelf (cos I was looking at it!) so if you've got a big beefy amp, the chances are it won't be able to hold it.
chrisw is offline
Old 11-11-2005, 1:01 PM   #10 (permalink)
Daddy k's Avatar
Thanks: Gave 312, Got 250
well i would do what i have, and that is connected a cable to every connection even thou i dont use it!
now im sure you could get some connectors to connect the xbox cables to ones you mount into the wall when the time comes.
that way you have multi use cables mounted into wall rather than an xbox only one!
so you can hot swap perhaps when ps3 comes out etc.
i nice look i think would be the ikea floating shelves with the equipment all on them , very nice and smooth yet still showing ur nice kit off.
a few lads have done it on here and really looks nice
Harman Kardon AVR230 Amp. BK Monolith DF subwoofer. B&W VM1 speakers x5.
Samsung Q96 50" HD plasma running Sky HD @ 1080i
Harman Kardon DVD 22. Sky+ Multiroom. XBox 360 add me on LIVE:krismc1.
See my setup in members gallery:"dads new pad"
Daddy k is offline
Old 11-11-2005, 1:14 PM   #11 (permalink)
Azzin's Avatar
That looks a possible answer.
So what I would do is get that box, run the component leads I currently have from my DVD player into that little box, & connect that box up to the component 'in' on my TV?
Then I presumably just add the XBOX lead to that when I get it?
Sounds like a plan!
Feel free to correct me if I've got that wrong btw.
Azzin is offline
Old 11-11-2005, 1:16 PM   #12 (permalink)
Azzin's Avatar
Cheers-do you have any links to these by any chance?
Azzin is offline
Old 11-11-2005, 4:00 PM   #13 (permalink)
Azzin Spot on. Especially if you currently have DVD via component and you want to connect the XBOX via component.
The extra cost will be the component box and 1 extra component lead. Saves you switching them around as well. The JS tech boxes are excellent although I have no experience of this one.
Parklife is offline
Old 11-11-2005, 4:03 PM   #14 (permalink)
Daddy k's Avatar
nope but defo in the "get ur plasmas out for the lads" thread somewhere lol
Daddy k is offline
Old 11-11-2005, 4:08 PM   #15 (permalink)
Daddy k's Avatar
how bout
http://www.avforums.com/forums/attac...achmentid=3192
theresmore im having a nose for new ideas myself!
Daddy k is offline
mount, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Best 42" tilting wall mount Ponty Plasma Brackets and Mounts 3 23-07-2005 11:19 AM
What are typical wall mount install costs? UKseless1 Plasma Brackets and Mounts 17 12-07-2005 11:23 PM
Wall mount Samsung LE32R41B magper LCD Brackets and Mounts 0 27-06-2005 3:33 PM
42 pv500 type of wall mount?? tim k Plasma Brackets and Mounts 3 03-06-2005 9:32 PM
Quick Q? - Panny PW6 and Slimline wall mount D J Fryer Plasma Brackets and Mounts 6 29-06-2004 3:13 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
