AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 07-11-2005, 5:16 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Which wall mount for Pioneer PDP-436XDE?
Finally making the big buy and investing in a Poineer PDP-XDE436 for Chrimbo. I intend to wall mount it but haven't figured out how to bury the cables in the wall and make a neat job of it. Fortunately it will only have the two black and white cables and a mains feed. Anyways....what I really want to know is what you guys have used to mount it on the wall, the pioneer ones or another make? All suggestions on a postcard please. Oh and if you have any ideas on burying cables let me know.
Ripstop is offline
Old 07-11-2005, 5:21 PM   #2 (permalink)
My 436XDE was delivered today
Following advice from another forum member I have gone for the flat mount supplied by RS100 (they advertise on this site). It was Ģ65 including delivery, although it is basic it looks up to the job. I'm planning on installing it tomorrow.
If you hear a load bang and then crying you know it did not work
Dave A is offline
Old 07-11-2005, 11:09 PM   #3 (permalink)
Let me know how the installation goes
I have visions of drilling several large bolt holes in the wall and the neighbours going potty. I saw some info in another thread and it does look up to the job. Some of the manufacturers mounts are very espensive for what they are, even though they may have to hold up several tens of Kg of glass and metal.
Ripstop is offline
Old 08-11-2005, 7:37 AM   #4 (permalink)
BigBilly's Avatar
Thanks: Gave 21, Got 4
I used the Pioneer wall mount for my 506.
No faffing about involved, easy peasy attaching parts to panel.
4 screws to fix mount to plasterboard wall (used noggins).
Up it goes, 30Kg on the wall, safe as houses, completed in about 2 hours. Only took that long because I had to insert noggins behind plasterboard.
Billy
BigBilly is offline
Old 08-11-2005, 9:14 AM   #5 (permalink)
Thanks: Gave 4, Got 77
Wouldn't plasterboard be sufficient without noggins as long as enough fixings of the correct type were used? Say 6 or 8 of these http://www.screwfix.com/app/sfd/cat/...41105&id=12635 ?
kevlar is offline
mount, pdp436xde, pioneer, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wall mount Samsung LE32R41B magper LCD Brackets and Mounts 0 27-06-2005 3:33 PM
42 pv500 type of wall mount?? tim k Plasma Brackets and Mounts 3 03-06-2005 9:32 PM
Help, Speakers to hide my wall mount Plasma chelleon Speakers 7 04-08-2004 1:46 PM
Quick Q? - Panny PW6 and Slimline wall mount D J Fryer Plasma Brackets and Mounts 6 29-06-2004 3:13 PM
Fitting a Panny Th42pwD4 Unicol Wall Mount bluebear Plasma Brackets and Mounts 6 05-11-2002 8:20 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
