| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Average width of wall mounted plasma?
Hi all
__________________I'm building a home cinema in a converted barn - and am not far off completion (the structural stuff anyway!). I plan to use a ceiling mounted screen and a projector - but will want to use a plasma on the wall for daytime use. My question is, and I know it is a difficult one to answer - but how far away should I keep my screen from the wall when it is lowered - to enable to to retrospectively fit a plasma on the wall behind it (for those daylight hours and parties)? Thanks in advance Simon My home cinema http://thehawthornes.fotopic.net/c652609_1.html ::Screenplay 7205::Monitor Audio RS8, LCR, RSW12 and 4xRSFX::Draper 106" 16:9 Screen::Pioneer VSX-2014i::Pioneer DVD-868AVi::Sky HD::HTPC with MCE::Soundstyle Hi-Fi Rack XS105:: |
#2 (permalink) |
My PHD8's front face is 12cm from the wall (using a slimline wall mount).
__________________Hope this helps. REB AV: Panasonic PHD8 (42") | Denon AVR-2105 | Panasonsic E95H DVD-R | Sky+ HD | Denon CDR-W1500 CD Player/Recorder | Harmony 895 Remote | Mission Speakers |
#3 (permalink) |
I have a wall mounted plasma and drop down screen as well. I gave it 20cm to be comfortable. Depends on the diameter of the rod on the base of the electric screen though, so measure once, then measure again. If you're using a standard wall bracket though (no tilt/cantilever) the front of the plasma is unlikely to be more than 15cm from the wall.
#5 (permalink) |
You've got your PV500 in very very tight there Mal, 95% of mounts make vieras 180 com thick.
My screen drops down at 125mm, clearing the plasma by 5mm, it's a PHD8, and the weight bar on the screen is 10mm thick. I've done it tighter than this before, by providing a 'ramp' at each side to ensure the bar never snags on the plasma in a draught. The screen can then run down the last 60 or so cm in a kind of 'track'. If the room is big, this is a good idea anyway, as larger rooms always have air currents, making a simply hanging screen flap about. |
#6 (permalink) |
Thanks all for your info - I'll go for 20cm....!
__________________Regards Si My home cinema http://thehawthornes.fotopic.net/c652609_1.html ::Screenplay 7205::Monitor Audio RS8, LCR, RSW12 and 4xRSFX::Draper 106" 16:9 Screen::Pioneer VSX-2014i::Pioneer DVD-868AVi::Sky HD::HTPC with MCE::Soundstyle Hi-Fi Rack XS105:: |
| Bookmarks |
| Tags |
| average, mounted, plasma, wall, width |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 42 Inch Plasma wall mounted on Plasterboard | andycharger | Interconnects, Speaker Cables and Switches | 5 | 29-08-2005 9:44 AM |
| wall mounting my plasma , scared about screws | DarkBytes | Plasma Brackets and Mounts | 14 | 04-03-2005 10:13 AM |
| finally plasma on wall!! | suniil | Plasma Televisions | 5 | 21-02-2005 1:06 PM |
| UT 2004 Demo | Stellavision | PC Games | 22 | 05-04-2004 2:18 PM |
Global Gold Web Hosting |
