| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
PV500 wall bracket
Quick question, can't find answer in other threads. What is the thickness of the plate on the mount bracket and does it go flush to the wall, or are the fixing points raised? I ask as I want to get the bolts and my screen isn't delivered yet. I'm assuming a bolt that can fix material up to 10mm thickness is OK (guessing bracket is 3-4 mm and flush) but next option is 25mm.
Thanks. |
#2 (permalink) |
The metal on the standard wall bracket is around 2mm thick and does lie flush to the wall. I used 6 solid wall bolts and could happily hang off the bracket when finished. Bolts for 10mm will be absolutely fine.
#4 (permalink) |
#5 (permalink) |
Depends what screen you are mounting.
Why not check out this link which is actually on these forums... http://www.avforums.com/ad_click.php?adid=48&zoneid=82H |
#6 (permalink) |
You need wxtra depth mounting bars or 45m spacers for use with the vieras because of the beer belly at the bottom of the plasma.
__________________AV: Panasonic TH-42PV500 Digital SLR: Canon 350D with Sigma 10-20mm, Canon 24-105 f4 L IS, Canon 50mm f1.8, Speedlite 430EX and handgrip, Crumpler Geekstar MY PICS---FLICKR Consoles: XBox 360, Wii, PS3, Gamecube, N64, Black NDS lite, R4DS |
#7 (permalink) | |
I prefer to think of it as it's ar*e rather than a beer belly Jet_andy, This thread might help, Panasonic TH42PV500 WAL (installed) + other kit some time soon... Cheers |
| Bookmarks |
| Tags |
| bracket, pv500, wall |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| PV500 with Wall Bracket - ok for my Alphason stand? | AndyH | Plasma Brackets and Mounts | 7 | 21-12-2005 9:31 AM |
| Wall bracket for the JVC LT26DS6BJ | Tony_R | LCD Brackets and Mounts | 3 | 09-09-2005 8:41 PM |
| how much for a wall bracket!? | richard plumb | LCD Brackets and Mounts | 0 | 28-08-2005 10:11 AM |
| Sharp's own wall bracket any good? | Hikikomori | LCD Brackets and Mounts | 1 | 11-11-2004 3:40 PM |
| Hitachi Wall Mounting Bracket - Good Question | AKM | Plasma Brackets and Mounts | 0 | 01-11-2004 1:15 PM |
Global Gold Web Hosting |
