AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 20-10-2005, 5:42 PM   #1 (permalink)
Thanks: Gave 45, Got 31
436-XDE wall mounted - opinions needed please.
Please visit this collection of photos, they show my old Pio 434 on its swivel stand, on my glass Plasma stand.
However, it developed a fault and I was partially refunded by the retailer, so I'm in the market for a 436 XDE.
I picked up a template whilst visiting the Pioneer stand at the recent Scottish Hifi show. This is the size of the 506. I've pinned it to the wall where I would like to mount my 436. (photos attached)
Should I be aiming for a 506 instead?
Is this about the correct height?
Does anyone think it would look better on the swivel stand (my wife does)?
http://www.byphotos.com/album/1148046
Thanks for any replies!
Nikon D40 | 18-55 | 55-200 VR
flickr
PDP-434HDE is offline
Old 20-10-2005, 5:44 PM   #2 (permalink)
Thanks: Gave 5, Got 1
I think because you've still got the cabinet underneath when it's wall mounted, I prefer the table top look otherwise it'd look great on the wall
johnhy is offline
Old 20-10-2005, 7:19 PM   #3 (permalink)
Thanks: Gave 62, Got 17
For me mate, wall mounting a plasma is the only way to go.
I think you should go for the 50" if you can stretch the budget but make sure that your viewing distance is sufficient so you dont get the noise (visible from about 4-5 feet on the 506) otherwise you wont enjoy this one like you did your 434. Otherwise get the 436 (mine is due to arrive 2 weeks tomorrow!)
kamaran is offline
Old 20-10-2005, 8:24 PM   #4 (permalink)
gizlaroc's Avatar
Thanks: Gave 24, Got 186
Only mount it that high if you are going to wall mount your centre speaker too, you really don't want the sound to be obviously not coming from the screen.
No Darling.......I've had it for months
You can ask as many times as you like, but the answer will always be the same........
"Get a bloody demo and decide for yourself!"
gizlaroc is offline
Old 21-10-2005, 9:13 PM   #5 (permalink)
Hi, well, I always thought the idea of a plasma was to wall mount it, after all it's one of the benefits of having a plasma - the fact that you can actually hang it on a wall!
Having said that, it does look a bit odd with the glass table below, the table just looks like it's missing something, maybe thats because I just looked at the pictures with the table top mount first. Hmmmm, so basically, I've been no help at all!
Wall mount it and move the table, thats what I think.
rich-t is offline
Old 21-10-2005, 9:39 PM   #6 (permalink)
No you have been : my quandry exactly!
flickr
Old 21-10-2005, 10:18 PM   #7 (permalink)
seconded!
kamaran is offline
Old 21-10-2005, 10:25 PM   #8 (permalink)
BeelzebubUK's Avatar
Thanks: Gave 19, Got 8
I think the height is spot on for the wall mounting. Not too high like a few that I've seen.
I would say either move the existing cabinet or get something thats wider and lower instead (which is what I'm probably going to do). I've seen some stunning setups with a wood finish low/wide unit underneath a wall mounted plasma.
AV : Panasonic TH-46PZ85B | DVDO iScan VP50 | Onkyo 605 | Canton CD206 5.1 | SkyHD | Harmony 885 RC | Wii | Xbox360
HD HTPC : Antec Fusion V2 Black | Abit Fatal1ty F190HD | Intel C2D E6600 | OCZ 2GB DDR2 800 | LG HD-DVD/Blu-ray | ATI HD4650 Passive | Gyration Mouse/Keyboard
BeelzebubUK is offline
436xde, mounted, needed, opinions, wall
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wall mounted hi-fi system - what is available Judith Hi Fi Systems and Separates 1 29-07-2005 9:03 AM
Cables ofr Wall mounted LCD hamd01 Interconnects, Speaker Cables and Switches 0 15-06-2005 8:56 AM
Wall mounted Viera Genesis Plasma Brackets and Mounts 4 22-09-2004 7:32 AM
Wall mounted centre? ab1385 AV Stands, Cabinets, Seating and Furniture 1 28-08-2004 11:47 PM
Wall mounted KEF eggs?? NAU Speakers 3 11-07-2004 10:43 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
