| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Best Wall Mount for Panasonic TH42PV500?
I have just ordered a TH42PV500 (yes JL, expensive at least they have stock...) and am looking for a wall mount for it.
Any suggestions on a good (easy as possible to put up) wall mount for it and who might have stock? It will be flat mounted to the wall, no need for tilt/swing. Any thoughts? Barry |
#2 (permalink) |
Posts: n/a
The universal ones will fit with spacers (45mm).
I found the best one was from RGB direct, as it tilts UPWARDS, so when you have you plasma on, you can hook it on the top bar and tilt it up to get your cables connected easier, It is Ģ140. name: RDPF1 The plasma sticks out approx. 140mm. http://www.rgbdirect.co.uk/ProductDe...UNumber=102399 Last edited by mal60908; 03-10-2005 at 6:37 PM. |
#3 (permalink) |
I followed Mal's advice and chose this over others including Pana's own (Thanks, Mal).
I bought mine from www.audiovisualonline.co.uk for Ģ90. (The model number is PF1.) |
#4 (permalink) |
Thanks for the quick replies.
The PF1 looks good, three quick questions before I go ahead and purchase one 1. Are there any extra bits I need to buy if I have the Pana Plasma and the Bracket (raw plugs, spacers, screws?). It is bolting to an outside wall? 2. Is it possible to mount the screen with one person or do I need to get a friend in to help? Not sure how easy the brackets fit together and how heavy the Pana is... 3. How many of the bolts did you use to mount it to the wall? PS: JL Say they are delivering the TV on Monday ![]() Barry |
#5 (permalink) |
Managed to find same mount on ebay for half the price. So maybe worth having a quick search. Will require at least six bolts/plugs to mount, try any diy store for heavy duty hanging bolts. Outside wall should be solid. No way will you be able to mount single handed unless you are very strong - approx 45K plus need to line up hanging bar. ![]() |
#6 (permalink) |
if you don't require tilt and want a slim profile have a look at the RS100 bracket - you can get them on Ebay or Amazon - Amazon being the cheaper option. Fixings wise - homebase do some heavy duty screws by Plasplugs that come with the rawlplug on them for about a fiver for ten. The more you put in the less stress on each. As for putting the plasma up yourself there is no way you will be able to line up both arms of the bracket unless 1.) you are extremely lucky 2.) you are 7 feet tall and built like arnold... |
| Bookmarks |
| Tags |
| mount, panasonic, th42pv500, wall |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wall mount Samsung LE32R41B | magper | LCD Brackets and Mounts | 0 | 27-06-2005 3:33 PM |
| 42 pv500 type of wall mount?? | tim k | Plasma Brackets and Mounts | 3 | 03-06-2005 9:32 PM |
| Help, Speakers to hide my wall mount Plasma | chelleon | Speakers | 7 | 04-08-2004 1:46 PM |
| Quick Q? - Panny PW6 and Slimline wall mount | D J Fryer | Plasma Brackets and Mounts | 6 | 29-06-2004 3:13 PM |
| Advice needed on Wall Mounting a Panny Plasma | the thing wnn | Plasma Brackets and Mounts | 7 | 22-01-2003 4:08 PM |
Global Gold Web Hosting |
