AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 30-09-2005, 2:33 PM   #1 (permalink)
Panasonic stand query
Does anyone know if it's possible for the Panasonic TY-ST42PX20 stand that is made for the TH-37PE30 & TH42PE30 to fit a Panasonic 42PV500b plasma?
Listerdude is offline
Old 30-09-2005, 2:45 PM   #2 (permalink)
Thanks: Gave 17, Got 63
I think the PV500 series is wider due to the speakers on the side rather than the base but you can adjust the spikes on the stand from what I know. Personally unless it says it supports the PV500 too I wouldn't chance it.
Panasonic TH37PV500 - PLAYSTATION 3 - XBox 360 - PS2 - PSP
Jim_Fear is offline
Old 30-09-2005, 2:57 PM   #3 (permalink)
The TH42PE30 speakers are on the side not on the base..I thought the PV500 did have it's speakers underneath are you sure you haven't got this the wrong way around?
I wouldn't be at all suprised to learn that it did fit though.
Old 30-09-2005, 4:59 PM   #4 (permalink)
Thanks: Gave 0, Got 5
im in exactly the same situation im getting my TV next week but JL dont know when Panny are getting the Pedestal stands in, for the meantime, im just gonna use the polystrene and have it on the floor, just to try it out, cant wait. JL did say they hope the stands will be here by next week. So hopefully Panny will get them in sooner rather than later.
AV Setup: 42PV500PED, Xbox 360. PS3. Win Vista , Sky+HD with 500gb, Itouch, Archos 5 250gb
Xbox and PS3 Gamertag: SinkingRat
Playing: Tombraider Underworld, COD 5, Mirrors Edge, Banjo Kazooie, Far Cry 2, Dead Space, Fable 2, GOW 2, Merc 2
tscotsman is offline
Old 30-09-2005, 5:14 PM   #5 (permalink)
VTR
Be careful about just using the polystyrene to stand it in/on until the pedestal arrives, the screen is quite a weight (40kg!) & could topple over. It would be such a shame if it was damaged after such a long wait
BTW, the pedestal stand weigh's quite a bit too!!!
Plasma: Panasonic TH-37PV500B
A/V Reciever: Sony STR-DB1070
DVD Player: Sony DVP-NS900V
Speakers: Mordaunt Short
Sub: REL Quake
VTR is offline
Old 30-09-2005, 5:49 PM   #6 (permalink)
your right m8, but mal had already done this and it seemed to him that it was sturdy enough, but your absolutely right that care needs to be taken and get it on the Pedestal as soon as possible. Hopefully they will arrive next week also, just to be on the safe side.
panasonic, query, stand
Refbacks are On
Thread Thread Starter Forum Replies Last Post
My NEC Vs. My Panasonic gizlaroc Plasma Televisions 49 15-02-2005 10:21 AM
Philips 32PW9509 vs Panasonic 32PD50 (pretty long) Goggleyes CRT Televisions 3 19-01-2005 1:14 PM
WHY I HATE PANASONIC (But Will Probably Buy one now!) Suave Plasma Televisions 18 21-12-2004 9:58 AM
Pioneer HDMI / Panasonic & Scaler queries PhilAllaway Plasma Televisions 0 04-12-2003 10:17 AM
Buying a Panasonic 42 inch Plasma ajb Plasma Televisions 56 04-07-2002 10:05 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
