AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > Plasma Televisions > Plasma Brackets and Mounts
dekomount>TV Brackets >TV Wall Mounts
>LCD TV Bracket >DVD Brackets
LinkBack Thread Tools Display Modes
Old 23-11-2003, 9:11 PM   #1 (permalink)
frenchy
Posts: n/a
Angry techwood brackets
Hello, wondered if anyone can advise a clueless new member who has saved and ordered a TETCHWOOD PLASMA from DIXONS. Waiting for it to arrive, nowstate they are out of stock (after managing to charge my card). I want to wall mount it but could not afford £300 extra they charged. Can anyone help me as to what type of brackets I need and how much (Dixons were as much use as a chocolate teapot). Thanks
Old 23-11-2003, 9:24 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,104
there is a thread in pwer buy forum i think about a universal wall mount for plasmas also try unicol.
PS welcome to the forum as you may know there are a couple of threads on the techwood unit around.
hornydragon is offline
Old 23-11-2003, 9:27 PM   #3 (permalink)
Assured Advertiser
see here: http://www.avforums.com/forums/showt...threadid=91217
Not bad if it will fit, for under £130
Old 23-11-2003, 9:46 PM   #4 (permalink)
frenchy
Posts: n/a
Thanks for the welcome/advice I shall have a search and inform all you new TECHWOOD owners what I find.
There appears to be a huge void in information on this plasma with regards the sales staff of dixons/currys they couldn't even tell me where they are made.
Reading the other threads have helped alot.
Old 25-11-2003, 1:46 PM   #5 (permalink)
Thanks: Gave 1, Got 3
The techwood i have came with a wall mounting bracket, i would'nt trust it though so its confined to the loft, wife will not let me take out the fire place in any case
Ron39 is offline
Old 17-12-2003, 3:46 PM   #6 (permalink)
officewaller
Posts: n/a
Would you like to sell it?
Regards
Officewaller
Old 21-12-2003, 2:00 AM   #7 (permalink)
marcus32
Posts: n/a
TECHWOOD BRACKETS
HI,
I JUST GOT MY 42 INCH TECHWOOD PLASMA TODAY AND IT COMES WITH A BRACKET AND FITMENTS ON THE BACK OF THE SCREEN, SO YOU DON`T HAVE TO PAY THE £300 TO HAVE IT FITTED ( A BIG CON, BY DIXONS AND CURRYS) IT HAS 4 BIG BOLTS TO FIT TO THE WALL THAT`S ALL, AND THE SCREEN SLOTS INTO THE BRACKET.
I`M PUTTING MINE UP TOMORROW, SUNDAY, SO WILL TELL YOU HOW I GOT ON, WILL PUT THE CABLES (THE 2 FROM THE PLASMA)INTO THE WALL AFTER XMAS.
YOUR`S MARCUS.
brackets, techwood
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
