AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Peripherals and Consumables
LinkBack Thread Tools Display Modes
Old 30-06-2007, 10:45 AM   #1 (permalink)
Thanks: Gave 5, Got 4
Problems with my Epson R300 printer
I am having problems with my Epson R300 printer. I have just replaced the ink and now 2 of my ink cartridges don't work at all now. I have run 10 test in a row and they still not working. I had problems last time I changed some of my Cartridges but after a few test they where OK. Does any one know what I could do to get the printer working OK.
blakeyboy is offline
Old 30-06-2007, 1:44 PM   #2 (permalink)
Thanks: Gave 50, Got 177
Re: Problems with my Epson R300 printer
Change the two non functioning cartridges ? ?
Steve.J.Davies is offline
Old 30-06-2007, 2:32 PM   #3 (permalink)
They are 2 of the inks that I have changed. So they are brand new.
Old 02-07-2007, 1:10 PM   #4 (permalink)
Short of trying them in another Epson what choice do you have ? ?
Old 11-08-2007, 6:46 AM   #5 (permalink)
Thanks: Gave 284, Got 1,489
Does anyone have experience of this ( otherwise fine printer) having a problem with paper feed. I'm about to chuck mine in the skip, frankly
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
senu is offline
Old 11-08-2007, 7:34 AM   #6 (permalink)
Synchro's Avatar
Thanks: Gave 93, Got 93
It might be what happened to me and when I researched it I found out:-
I'm afraid its likely that you haven't used your printer enough. Yes this exists!!!
I had to replace my last Epson Printer because I used it too infrequently. The ink dries up in the very small apilaries. People have taken them apart and cleaned them, with solvents, but its not a job for the faint hearted. It very messy, time consuming and in my case, too much work. I binned an otherwise perfectly, hardly used Printer >:E
Vista PC Specs Here99999999.Vista HTPC Specs Here
Add yours Here
Synchro is offline
Old 11-08-2007, 8:24 AM   #7 (permalink)
Thanks: Gave 2, Got 12
Smile Re: Problems with my Epson R300 printer
Have you been in touch with your local Epson Express Service Centre and what have they said about your problems?
To find your nearest Centre. Just look up Epson Express Service Centre on 'Google'
Caralfa is offline
Old 11-08-2007, 11:22 AM   #8 (permalink)
WildeKarde's Avatar
Thanks: Gave 13, Got 24
I had a similar problem before but seemed to clear up when I changed the cartridges (and it was being used regular).
It's almost like the printer clogs up but it was the cartridge that had the issue and not the printer.
Best thing as suggested would be to speak to Epson and see what they say.
WildeKarde is offline
Old 12-08-2007, 12:52 AM   #9 (permalink)
Thanks: Gave 0, Got 64
Epsons are know for many issues it's a shame really they are alright printers for first 1-2 years then they always mess up this is one of the main reasons I stay clear of them now and stick with HP they last very long time but problem with HP ink is expensive.
triplea4uk is offline
Old 02-09-2007, 1:26 AM   #10 (permalink)
I had this problem with mine and dribbled a very very small ammount of video head cleaner type fluid in the head and left it over night ,
I then used ssc service utility from net (search google) and did a mega initialisation clean with that and all has been fine since although I now use ssc to clean heads rather than epson util
Barmpot is offline
tonyten (03-10-2007)
Old 03-10-2007, 3:46 AM   #11 (permalink)
tonyten's Avatar
Thanks: Gave 13, Got 25
Thank you very much for that info, I was having some problems with my black ink cartridge and it turns out it was empty!? I only installed it last week...ebay the seller advertises them as genuine....yeah right.
Sharp LC37X20E - Logitech Z-5500 - PS3 - PSP setup
PC AMD64 X2 3800 @ 2.45GHz, 2GB OCZ Gold, nVidia 7600GT XT, Hiper Type-R 580W
Media PC: AMD64 3700, 1GB Kingston VRAM, nVidia 6600, Thermaltake TR2 420W
Official SCEE Beta Trial Member
tonyten is offline
Old 03-10-2007, 12:25 PM   #12 (permalink)
Cartridge may be an original as claimed but what ink has it been re-filled with? Another lesson learned! Also remember that all cartridges and the ink they contain all have a limited "Shelf Life" stored under the correct conditions. Only buy from known and trusted Traders.
Or if you are after cheaper makes of cartridges ,again only buy good quality Compatibles filled with a known quality of ink. Most compatible cartridges are made in China or Far east and so is the ink that is put into them. Try and buy from a Manufacturer who actually makes and fills the cartridges with ink that is also made in the EU or Britain. They are still there.
Or to save even more money invest in a C.I.S (Continuous Ink System) which can save you a fortune in the long run.
Caralfa is offline
epson, printer, problems, r300
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
